Hi aniq cdn143... Downloading Music to your MP3 Player
1...You must download and install Windows Media Player 11 on your computer. NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11. If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10. 2...After you have downloaded and installed Media Player on your computer. 3...Open Media Player on your computer. 4...Install all your music into Media Player that you want to install on your MP3 player. 5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on. 6...Media player should recognize the MP3 player and sync with it. 7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player. Please take time to rate me thumbs up.
1...You must download and install Windows Media Player 11 on your computer. NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11. If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10. 2...After you have downloaded and installed Media Player on your computer. 3...Open Media Player on your computer. 4...Install all your music into Media Player that you want to install on your MP3 player. 5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on. 6...Media player should recognize the MP3 player and sync with it. 7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player. Please take time to rate me four thumbs up.
hi yumpfan, I personally don't think that one is able to modify the player's firmware in the desired way, there is no button to it, too. Just too small. Please think about purchasing another player if you wish to have such function.
May be a bad USB cable. Check the connector on the end that plugs into the pc, something inside may be broken preventing the connection. Sometimes the flat plastic piece inside (white or black) breaks loose if you forced it into the usb port or felt resistance when inserting it. If it came with software, you may have to reload it especially if you are using Windows 98.
There are several possibilities:
1) The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.
2) You have the Hold switch engaged - unlock it
3) The PC's you are trying to connect it to are running Windows Vista - not compatible with Nextar
The songs you are trying to load to the Mp3 player are not compatible with the Nextar - a good test for this would be to connect your Nextar to the PC, open Windows Media Player, and click the Library tab, then the Sync tab - if a little blue "i" appears next to the song, it will not work with your Nextar. In fact, any song that is not in mp3 format or unprotected WMA (very few WMA's are unprotected unless you Ripped them directly from CD) will not play in the Nextar.xxx
