SOURCE: margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
SOURCE: Changing Margins
Cannot find a picture of this keyboard however the process would be similar to this. Move (return) the carrier to the left margin. Find the margin release key. It mat be labled M REL. or M. R. or something similar.
You may have to use it in conjunction with the code key, if this is the case the M REL or M. R. will be on the front of the key in a different color lettering.
Press the margin release key and backspace to where you would like the margin and then press the left Margin key. If these keys require the code key you will need to hold the code key down while pressing the release and set keys.
The right margin will reset in a similar fashion only space past the margin after hitting the release.
Hope this helps.
SOURCE: changing tabs and move the right margin over some
On the L. side of the T/W ketboard are the keysmar left, mar right,tab set, tab clear and mar rel. Space to the location thayou want th R. mar and press right mar key, if it stops at the R. mar. press and release the mar rel key. To clear tabs tab to the one you want cleared and press tab clear. To set a tab space to the position and press tab set.
DickyO
SOURCE: My set margins and tabs clear from memory when I
I was able to reach someone at Brother. He said that the typewriter does not store the margins and tabs. Seems unusual to me, but I guess I will have to take his word for it unless someone out there knows something different.
SOURCE: how to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
