JVC Smart TV Model LT-55N776 Issue with Showmax app - following message appears: "The license was not acquired: Indicates that an error occurred and the reason is not known." Any assistance would be appreciated
SOURCE: Problem with update install
download the update to flash drive using your pc then plug it into your ps3 and install it that way.(may take 2 or 3 trys).
SOURCE: i have a jvc tv lcd model lt-42e488 the green
is a inverter control board defective, need to be replaced.
SOURCE: I received an Error Code
hi,
Thanks in advance for choosing Fixya for assistance
I would like to make a clarification request on what
" Source " are trying to view programs on TV
Is it on the TV built in tuner or on the AV 'Input " ?
If ever you are watching through RF input , have you
tried connecting it using AV input?
If using AV INput have you tried other connecting cable?
or post cable you are presently connected.
Awaiting for your immediate answer and post the model
of your MTS PVR so we can start having possible solution
to your problem.
SOURCE: My LG Plasma TV Model
Please confirrm if the connection given is to the port that supports the signal as the message indicates.
If this is the RF signal then it must go to the RF tuner input of the Tv.
If the set top box is used you will need to connect the video and audio outputs to the corresponding video and audio inputs of the TV.
Please confirm if this has been followed.
SOURCE: Visio smart tv apps
You have to jailbreak it and if it's android I can install the app store
