Kitchen Ranges Logo
H
Heather smithson Posted on Jan 04, 2018
Leisure range oven and clock not working
I have moved into a house and the cooker was there,it is a leisure range double oven but I can't see the information plate clearly as is wearing I have taken some photos of it just wondering if anyone knows anything about them ,then clock has gone ff and the fan assistanted oven is not working but the other oven is working can anybody help
2 Related Answers
Anonymous
  • 399 Answers
  • Posted on Sep 23, 2008
SOURCE: hi my leisure alta cookers
ceramic plates and the fan has to be replaced as you yourself know whats the problem.
you can get the required parts at this link
www.repairclinic.com
just enter the model number of your unit and the part you require.
and if u want to do it manually you can check out this following link
http://www.applianceaid.com/micro.html
feel free for further queries.
thanks.
Anonymous
  • 462 Answers
  • Posted on May 08, 2009
SOURCE: having problems with fan assisted oven on leisure
Often these fan assisted type ovens have a safety that keeps th fan off if it believes the door is open. Look for uneven door closing or cracks in the door to frame closure. Is this a commercial convection oven?
I have a leisure cooker with 2 ovens and want to know where the fuse is located
The fuse is in your consumer unit. There is no fuse in the cooker itself.
Where is the fuse in a 2 oven leisure cooker
You main 'fuse' is the breaker. It does have a thermal fuse, but that has a different function. Information and videos that may help, but in questions like this a full make and model number are needed.
https://www.google.com/search?q=leisure+cooker+with+2+ovens%2C+fuse
I HAVE SMOKING AND NOISE FROM MY FAN ASSISTED OVEN. THERES A GRINDING NOISE OFF THE FAN ALSO
Sounds like fan motor bearings have died. You can likely search for a new fan online.
Rangemaster 55 leisure. My timer has stopped working
Hi Stella,
i am sorry for you, but you can forget repairing the timer.
You can replace it of course.
You do not need the timer to operate the oven.
For that you need to bypass the timer. The clock will stay working normally.
Although the 55 is smaller then the 110, the working of the clock should be the same.
Net link will give you more information and I hope you will fin the solution there.
Kind regards and a good weekend, Dik
Leisure Rangemaster 110 Electric Range Cooker How to bypass
28helpful
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 • Ovens
3helpful
Instruction/Owners manual for a Leisure Rangemaster 55 Auto
I have the just moved to a house with this same oven. I can't find the exact manual online, but the timer/clock seem to work the same as this one..
http://www.leisurecp.co.uk/upl/15858-GR6CV.pdf
Top Leisure Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
