SOURCE: hotpoint aquarius fdw20 fault lights
yeah i had same problem turns out its a blocked outlet hose
SOURCE: I have a hotpoint ulitma washing machine that is
Error code E15 means pump time out, that it is to say the water is not pumping out enough in the time alloted by the control module.
There must be some kind of blockage or restriction in the pump or the outlet hose, so you need to check these.
Please rate my solution.
Thanks.
SOURCE: Hotpoint WMF720p - getting message F05 can you
You need to check and clean the pump filter.
If there is no filter located at the front of washer, (check handbook),
Then remove the rear lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Fit back and test
Thankyou.t.
SOURCE: Whirlpool washing machine "clean pump" error light.
take top off machine. look down right side and you will see a disc about 50 mm in diameter, attached to this is a small flexible rubber pipe, take this off at the disc and blow through it,( you will need some type of pipe to connect to the rubber pipe).this worked for me with the very same problem.
SOURCE: Hotpoint Ultima wash machine has error code F05
hello you have a jammed pressure switch on full it says so if removed the blockage have u tired replacing the pressure siwtch. You can sometimes test them by blowing into the part where the pressure tube goes, but only blow gently. You should hear it click when you blow into it.
Obviously the machine will need isolating first and the switch will need removing from the machine. it depends how handy you are if you can change brakes in a car this will be an easy task to replace hope this helps please remember to rank how this helps you and if i can help in any other way please write me back have a great day
rickead1
Testimonial: "Thank you for the quick response, since posting I have done a little more research and believe you are 100% correct. I"
