Question about Kipor Electrical Supplies
Kipor digital invertor series 2 GS 3000 overload lamp on, motor runs, but no power
    Habit-Forming:
    New Friend:
  • 111 Answers
Hi
the inverter has puck up
Posted on Jan 12, 2018
4 Suggested Answers
SOURCE:
  • 57 Answers
SOURCE: IGBT FAULT ERROR KEEPS OCURING ON DF6 340 IVERTOR
E30 IGBT fault If an excessive current is applied at an IGBT (transistor in the power end stage), the output voltage
is switched off to protect the transistor.
Sounds like maybe a fan has gone bad and is drawing too much current.
Try disconnecting the fans and reconnecting one at a time. Also check
the fans to make sure they turn free and are not blocked.
Posted on Aug 17, 2009
  • 243 Answers
SOURCE: kipor 3000 motor runs fine but it will not make
open gen and check wires. take out capacitor and measure value. if damaged on the outside replace capacitor. most of the times this is a course. otherwise measure resistance on statorwindings and between statorwindings and earth.
Posted on Feb 12, 2010
dustydis
  • 373 Answers
SOURCE: kipor ig6000 overload alarm
most warning and alarm's are set less than what the manufacture rating is. it's a safety feature without it we would overload all our stuff
Posted on Sep 23, 2012
Kipor digital invertor series 2GS3000 overload lamp on motor runs, but o=no power how do ifix this. Regards Glen
You most likely have overloaded the unit. There is an overload reset aka circuit breaker on the side that must be reset.
Sep 11, 2018 | Kipor Electrical Supplies
My kipor KGE 6000 Ti generator overload light is on, and there is no current output.
Read the instruction manual. If you are certain you did everything right and the generator does not behave as intended then return it to the supplier as faulty.
Jan 27, 2018 | Kipor Electrical Supplies
Hello I have a kipor 3000 generator I cannot get it started, the generator was in storage and it just won't start can you help out
It helps that you said it was " in storage".
I am assuming the unit runs on gasoline.
If so, it is probable the gasoline has turned to gummy deposit and the carburetor must be rebuilt.
This is common with any gasoline engine that sits for a long period of time.
I have this problem with my 2 generators.
In the future, if this was the problem, the gasoline must be drained out at the very start of the "storage" time.
God bless your efforts.
Jul 15, 2016 | Kipor 3000 Watt Generator
I have a Wacker portable Gen gs 5.6 It runs good but it also don't put out power ether
I suspect the inverter module has failed. The module failed on my kipor gen and produced the same problem, ie no A/C outpu. Module was about $300 for Kipor. Fitted myself, problem solved.
Dec 06, 2014 | Electrical Supplies
Tharmal overload
MAY BE YOU HAVE MISS CONNECTED THE TEMPERATURE SENSOR.
Feb 08, 2014 | MGE Galaxy 3000 UPS System
Kipor ig6000 overload alarm
Sep 23, 2012 | Kipor Electrical Supplies
My kipor KGE 1000Ti starts fine but after several minutes stops generating and the red overload light comes on, with the demand for power left connected and the generator still running electrical...
You may be UNDERLOADING the generator and it may be unstable with such a light load... see if it might behave running a heavier load... put a 100 watt light on it as a test,
Jul 25, 2010 | Electrical Supplies
Kipor 3000 motor runs fine but it will not make power? I have looked at everything. it is 2 years old off of warrenty and no one can tell me why.
Feb 09, 2010 | Electronics - Others
Electrical Supplies Logo
335 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
