Question about Sony Ericsson W960i Cellular Phone
How to hard reset sony ericsson w960i - Sony Ericsson W960i Cellular Phone
  • cojjot Jul 30, 2009
    code 0000 not working
  • Sony Ericsson Master
  • 1,511 Answers
I don't know what your query is, but let me tell you more than what you have asked.
If there is software problem(Bug), then a Master Reset or a Firmware update may fix your phone, if its a hardware fault, then you can take it to the service centre.
Warn you that, this will delete all your Personal Files, installed applications and Settings.
Back up your phone using the PC suit.
To Master Reset:
1) On your phone, Go to Control Panel -> Other -> Master Reset.
(The default code is 0000, but if you have chaged it, Enter that one)
To Update the Firmware
1) Download SEUS (Sony Ericsson Update Servise) from Sonyericsson website
2) Run it and Follow the instructions, update the Firmware even if it says you allready have the latest firmware.
If I was helpful, kindly do Rate! Regards.
Posted on Jul 30, 2009
  • Waqar Hassan
    Waqar Hassan Jul 30, 2009
    Sir if the default code "0000" does not work that means you might have changed it.
    Here is the solution, which i'v tested many times.
    i used XS++ with DCU60 cable (i.e; USB cable which comes in the box),
    Download 3.1 version here
    use XS++ 3.1 and Another version
    1) Switch off your phone,
    2) run XS++.exe
    3) In XS++, click Connect.
    4) old C on your phone and then insert the USB cable.
    5) u can get some information about your phone when it's connected,
    6) click or tick GDFS at the bottom.
    7) Then click Phone Lock, and reset it to 0000.
    8.) click Settings at the bottom, then Disconnect.
    9) unplug the USB cable, remove then reinsert the battery
    10) switch on your phone
    The code will be set to 0000
    Enter it, and chage accordingly.
    Kinda, You are done.
    If i was helpful, kindly do Rate!
I want know, about hard restart code for W 960 i
thank's
Posted on Sep 07, 2010
    Sniper:
  • 60 Answers
Hi buddy just go into the settings option then select reset phone then it will ask u the password if u have changed it then enter that one else enter the default one that is 0000
Hello, i changed my w960 screen and it needs to be calibrated. I cannot calibrate it since i cannot make the prope selectioins.i tried reseting it but again i cannot do the proper selection. Anyone has any idea how i can fix this?
Posted on Dec 08, 2009
    Problem Solver:
  • 11 Answers
Select control panel - other - set up wizard.. this is where you find the settings for re-calibrating the screen... if you can't use the touch screen to select the necessary options, then you can use the jogwheel on the side of the phone --- scroll up or down to highlight the option, then press the wheel in to select..
hope this helps.....
Posted on Dec 13, 2009
Im having the same problems.. were you able to solve this problem?
Posted on Jan 24, 2010
  • sassyrubie Jan 24, 2010
    I'm experiencing the same problem. Were you able to solve this?
Http://www.4shared.com/file/31320268/de535436/XS_version_31.html
asks password
Posted on Oct 22, 2012
I've approximitely 20k messages in sent box.. :) i think my phones message memory is full now.. thats why it doesnt send any message and i cant get the messages that are sent to me.. i couldnt reset it because of the code :(( and i tried the XS++.. it didnt work.. what do i have to do?
Posted on Oct 25, 2011
4 Suggested Answers
SOURCE:
SOURCE: sony ericsson W960i cell phone,
try dropping down ur cellphone in a 10 cm ht..then it will work..its true
Posted on Jan 21, 2009
nanbuenbrazo
  • 553 Answers
SOURCE: sony ericsson w960i touch screen doesnt work
Yes it can be fixed but you cannot fixed it by yourself, you will need software and flashing tools to do that or worst case scenario is that you might replace some damaged part on it, but it can be fix
just bring it to a cellphone repair man and will handle the problem
Posted on Nov 13, 2009
  • 75 Answers
SOURCE: W960i with broken screen. How do I retrieve contacts?
using the bluetooth u can transfer the contacts it wil be easy
Posted on Jan 27, 2009
How to format my sony ericsson w960i
how to format sony ericsson w960i without on
Aug 28, 2010 | Sony Ericsson W960i Cellular Phone
HI I ForGot Whats My Unlock Code For My Handphone (W960I) Help pls
To unlock a Sony Ericsson W960i you will first need an unlock code. You can call your phone carrier to get a free unlock code for your Sony Ericsson W960i. Your phone carrier will more in likely ask for your phone’s IMEI number. You can find your IMEI number on your Sony Ericsson W960i simply, by typing: *#06#. Once you have your free unlock code for your Sony Ericsson, we can get started with the unlocking process. Here are the steps:
Unlock Sony Ericsson W960i 1. Power up your Sony Ericsson W960i without the SIM Card in
2. Press the left arrow key/button once
3. Press the button * twice
4. Press the left arrow key/button once
5. The message “Personalize with MNC2′ will be displayed
6. Enter your free unlock code
If the above steps do not work you can try checking out this forum post on Sony Ericsson Unlocking. Otherwise, hopefully you have yourself a fully unlocked Sony Ericsson W960i phone. Best of all it was completely free. You can find the original steps from this Guide To Unlock Sony Ericsson W960i
May 28, 2010 | Sony Ericsson W960i Cellular Phone
I can no longer send messages to messages to my contacts.
do a phone reset then if that dont work call you provider they will help you fix the problem but i think a reset will work..
Apr 30, 2010 | Sony Ericsson W960i Cellular Phone
Sony ericsson w960i touch screen doesnt work how can i fix this, and can it be fixed?
Nov 13, 2009 | Sony Ericsson W960i Cellular Phone
My W960i internal 8 GB memory was corrupted!
You can try Factory Reset or Master reset. Also the best would be use SEUS and reinstall the firmware.
Sep 20, 2009 | Sony Ericsson W960i Cellular Phone
My W960i internal 8 GB memory was corrupted, how
how to storage 8 GB internal memory to sony ericsson (W960i) give to solution
Aug 02, 2009 | Sony Ericsson W960i Cellular Phone
Master reset
code is factory set at "0000"
Jul 09, 2009 | Sony Ericsson W960i Cellular Phone
Jan 27, 2009 | Sony Ericsson W960i Cellular Phone
Sony Ericsson W960i  Cellular Phone Logo
13,986 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
