SOURCE: have a hotpoint wt761 washing
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
SOURCE: Hotpoint Ultima Wt761 is displaying F-08 what can
First, try turning off the mains power to the machine for 30 minutes and switching it back on to see if the error persists. This indicates a problem with the heater relay or heater. This usually means that the relay cannot be operated due to a heater fault and that the heater will need replacing. A service call to replace it will be the quickest option.
SOURCE: My Hotpoint ultima washing machine
Sounds like your water pressure switch is faulty. You can replace this easily by removing the top panel, the part is round and about 2-3 inches diameter, it has a thin pipe connected to it that goes to the tub and 2 or 3 wires plugged onto it. H20 normally means not filling but sounds like the switch is faulty. Hope this helps
Testimonial: "Thank you i will try what you said many thanks"
SOURCE: my hotpoint ultima WT761 wont
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
