I want to get a refund on this product.
More info needed. Where did you buy it? What is the brand?
SOURCE: Almost new air mattress has a hole in seam. No
contact local vehicle trailer repair garage.they will probably have rubberised repair patches that they use on curtain sided trailers.it should do the job.
SOURCE: What can I use to
Hi rh57...
I will recommend that you use some contact cement, and a piece of thin plastic like a plastic drop cloth, shower curtain, etc.
Cut the plastic piece that will be using as your patch about 1" X 1" square.
Locate the hole in the air mattress, deflate air mattress, apply contact cement lightly to the air mattress approximatly 1" X 1" and the piece of thin plastic material you will be using as the patch over both entire surfaces of the patch and mattress...let it all dry about 20 mins.
After it is dry then apply the patch to the hole in the mattress, apply a weight to the top of the patch, let sit about half an hour and you are done
Hole fixed
Please take time to rate me thumbs up
