SOURCE: jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
SOURCE: after each shot the nail gun jams
hi visit your supplier and ask for a overhaul kit once fitted your tool will be licke new
best of look ian
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
SOURCE: My nail gun won't fire nails and is blowing It
Stop using it and take it in for service. If it is leaking air then an o-ring or seal may have failed (most likely guess) and it needs to be replaced.
