There are exceptions to this. For example, adjusting the White Balance is not available in the 4K Photo mode. See page 197 of the Advanced User Manual: ftp://ftp.panasonic.com/camera/om/dmc-zs60_adv_en_om.pdf .
I hope this helps.
SOURCE: burst mode on Panasonic Lumix dmc-fx50
I have, after sifting through the 144-page manual, figured out what the problem is! At some point you must have set the "Auto-Bracket" setting to on - I did the same thing! To turn this off, put it in any of the Scene or Manual Exposure modes, then press the up (↑) key until "Auto-Bracket" comes up. Then, using the left or right (←,→) keys, set it to Zero (0). This should hopefully solve your problem! :)
SOURCE: windows 7 compatible driver for panasonic lumix camera dmc-ls70
You need to go to the lumix website and follow links to support and/or downloads for drivers.
SOURCE: My Lumix DMC-TZ3 seems to
i think this is the CCD problem. did you recorded any laser show or direct exposer of ccd to SUN will do these kinda problems. take it to service center . replacing ccd will work . aaarwind
SOURCE: Panasonic Lumix DMC FZ30 - LCD white screen.
Firstly, use the following information at your own risk, I am simply providing my own findings for informational purposes. It may or may not be the solution to your problem. If you want a professional opinion, go to a camera repair specialist...
I have had the exact same problem. The screen on my Panasonic DMC-FZ30 started to go white with lines through it in certain positions, and then in all positions. Finally it went black.
I took my camera apart to try and find the source of the issue with my screen (by the way if you want to take your dmc-fz30 apart, there is a fantastic service manual download for free at: http://www.nemodus.info/fz30/docs/DMC-FZ30_DSC0508016CE_v1.pdf or if that does not work try http://elektrotanya.com/panasonic_dmc-fz30.pdf/download.html ).
I believe the issue stems from the contacts of the rotating screen. I would hazard a guess that somewhere along the flexi-cable there is some wear which has caused this to occur...
I have not yet solved the problem, however I do have two potential solutions.
1. I found a site where you can buy a replacement flexi-cable for the camera. The site is (http://g-plushk.com/product_info.php?cPath=53_56&products_id=653). The cable costs approx $12 (not sure which currency, it doesn't say).
The issue with this solution, after taking apart my camera, I could find no way to remove the cable completely from the swivel joint at the base of the screen. So you would probably have to buy the part and take it to a professional. (probably check first whether it is even possible to replace, I assume it is, as they sell the part...just my guess).
2. The second solution (easier in my opinion, but a bit more expensive I'm guessing). You can buy a replacement screen for the camera. Contact Panasonic for your closest spare parts distributor. I do not know the price for a replacement screen, but I would estimate that it is between $30 to $50 AUD. I would then install the part myself as it is fairly easy if you follow the service manual. However if you would prefer not to do it yourself, I would seek the help of a camera specialist to replace it...
By the way, just to put a repair in perspective. You can PROBABLY (not definitely) buy a second hand 'Panasonic Lumix DMC-FZ30' for somewhere between $80 to $120 AUD...
Hope that helps
Yes, the white balance can be adjusted while in the "P" mode (Program mode). The easiest way to do this is to use the Quick Menu button (QMENU button on the bottom with the trash can icon on it). Once pressed, you can navigate to the White Balance setting and adjust it to whatever you want. Incidentally, I was not happy just using the Panasonic user manual. I found a book called "Photographers Guide to the Panasonic ZS100" by Alexander White to be very helpful in learning how to use this camera's many features.
