whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
If the burner pressure is adjustable(some are not) you can use a small adjustable wrench to turn the gas orfice to lower the gas pressure. The orfice is usually located in the broiler/storage comaprtment at the very bottom of the range. It is the brass piece that goes into the burner venturri and is where the gas comes out. If your turn it clockwise it will decrease pressure & counter clockwise will increase pressure. If the flames are coming into the burner compartment that is quite an increase in pressure!!! Make sure the the range did not have the gas regulator removed. If it was then that would explain why the oven burner pressure is so high.
I just had my ignitor replaced. The ignitor glowed but it must pull a certain amount of amps before it will allow the gas valve to open. Once the ignitor starts glowing the gas should come on within 30 seconds. Now that I saw it done I realize it was something I could have done myself. Be sure the tech does not try to slip you a used ignitor as mine tried.
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
I am having a Whirpool 465 gas stove for 8 years with 3 top burners do not work - burn but with very low flame. Please provide suggestion to repair - remove the burners and replace them?
