Question about Maytag Washing Machines
Maytag Maxima MHW6000xw1 with error codes E02 and F06. The door locks, but nothing happens after that. Does anyone know how to fix this?
We tried replacing the main control board (the big one on the right, not the one attached to the control knobs) after we let it sit without power overnight, but that did not work. We also tried disconnecting all the other panels and re-connecting them--again no results.
OMG. So much blathering BS. I just fixed this by unplugging the machine FROM THE WALL for 20 minutes. Put the plug back in. Low and behold. Door unlock, everything reset, all is well.
Grow a brain people - just reboot ????....
Posted on Jan 25, 2019
3 Suggested Answers
SOURCE:
SOURCE: Maytag Maxima Front Load Washer. F01 / E02 error
Tip the machine up & look inside up high, you
should find a bag with the diagnostic service
manual & it has the codes
Posted on Sep 05, 2013
georgemsmith
  • 13 Answers
SOURCE: Maytag Maxima front load washer "master reset"?
To start, E01 and F06 means that your main central control board (CCU) and the motor control board (MCU) are not communicating with one another properly. The motor control board is located under the tub mounted to the floor of the washer. The CCU is mounted under the top panel of the washer and is the part with about 100 wires going into it. You'll want to remove the top panel and the lower front panel to check the wire connections and make sure they are all secure. If everything looks good, then you just have to somewhat guess which control board you want to replace first, either the MCU or the CCU. The problem is that there is no way to test and determine which part is faulty so it's just a guessing game. That's what makes this one of the worst errors to get. I generally replace the CCU first as that is the part that shakes around a lot more during spin and it's the first place that the power goes from the power cord if there is any fluctuation in power, so it makes since that this part fails more than the mcu.
There is no Master reset. The only thing you can do is unplug for 1 minute then plug back in.
I’m happy to help further over the phone at https://www.6ya.com/expert/george_083af2f0afc0328b
Posted on Oct 29, 2015
Maytag maxima ecoconserve washer My washer will not operate. The lights come on as if it will I hear a few noises, but water will not enter it and it does not operate. Error Codes are E02 and F06
you have a communication error from the UI (user interface) to the CCU (Central Control UNIT). It could be the wiring or the control itself
Feb 06, 2016 | Washing Machines
My may tag washer has codes F06 & E02 , what does this mean?
I beleive e02 is something to do with ur drain pump set up clogged or damaged water pump and hoses
Jun 15, 2015 | Maytag MHW6000XG Maxima High-Efficiency...
Washer will not run
f06 OR e02 error code means you have an interface communication error. the main control board isn't communicating with the front interface control board. if you pull the washer out and remove the 3 screws coming in from the back of the top panel. the top panel will pull straight back, up, and off. check all the wire connections between the two control board and make sure they are all secure. if everything looks good, then the interface control board may need to be replaced.
f01 e02 means that your motor control board is not reading the tachometer on your motor when it tries to turn the motor. it thinks that the motor is struggling. open the door and turn the basket to make sure it spins freely.
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
What do these 2 codes mean on my maytag washer , F06 and E02?
The error code E02 and F06 on a Maytag washer could mean that the hot water solenoid went out. It could also mean that that the hot water control is not working properly.
Sep 23, 2014 | Maytag Washing Machines
Maytag Maxima E05 & F06 error codes on washer
My F06 E05 error returns within a moment of clearing all errors. My Maxima has no tach line from the M to the MCU. MCU commo fault is a different error. So does anyone except Maytag really know what this error is? And Maytag only wants to send a service guy to bleed some money from you.
Oct 21, 2013 | Maytag Washing Machines
Maytag Maxima Front Load Washer. F01 / E02 error codes. Power on, kicks off cycle, locks door, but will not call for water.
Sep 04, 2013 | Washing Machines
Maytag maxima codes F06 and E02: Tried doing a spin/rinse/drain on an empty machine. Timer seems tpo be working but cannot hear water filling or barell spin. tried to shut off and door is now locked.
see this causes and fix it. God bless you
POWER/CANCEL press for to cancel the error codes.
First to unlock depending on model. There will be a pull tab either under the lower kick panel, behind the filter cover, or under the top panel. Pull this tab to unlock the door. Now you can remove the clothes and water. Refer to the owners manual for the location of your emergency door pull tab.
Door Switch
You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.+fuse thermal +c.breaker
Oct 16, 2012 | Maytag Maxima EcoConserve Series MHW6000X...
Washing Machines Logo
1,439 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
