Hi Lainee London
You had not specified where do you want to make your font size larger. And you did not tell us which operating system you are using - these information would help us find you a suitable answer faster.
Anyway, there is a way to zoom in or out of most programs, that will show fonts in larger or smaller sizes: roll up and down you mouse's scroll wheel while you keep pressed the Control key (Ctrl) in your keyboard.
In case you are using Windows 10, there is a small tutorial showing you how to do it, by accessing the link below:
How to Change Font Size in Windows 10
Hope you may find this answer helpful!
Best regards,
Miguel L. martitns
On what?
More info please...
SOURCE: Font Size
Hi
Turn unit on.
Press Function
Press the arrow keys (beside funtion key) in will scroll thru all the functions. Once you get to "Size" press function again. You the use the arrow keys again to change the size.
SOURCE: I can't figure out how
Try this solution to change the font size:
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
1. SIZE1 equals Standard Size.
2. SIZE2 equals Double Width.
3. SIZE3 equals Double Height.
4. SIZE4 equals Double Width & Double Height.
5. SIZE5 equals 4 x Width & Double Height.
6. AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Hope this helps.
SOURCE: Toshiba Laptop spontaneous font size change
Disable the dreadful "pinch-zoom" of the Snyaptics touch pad.
How it is supposed to be used is at
http://www.synaptics.com/solutions/technology/gestures/touchpad . However, I tried these "gestures" and none of it worked on my touchpad.
On Windows7, one can disable this poor excuse for a feature by going to Control Panel->Hardware and sound->Devices and printers->Mouse->Device Settings->Settings [button half-way down, on the right]->pinch zoom. Then uncheck "enable pinch zoom".
SOURCE: My font for my text
try using the volume button on the side, it happened to me too and i didn't know what i did until i accidently pressed the button again and it changed
AOL Mail is an email service provided to the customers of American Online as well as Web users.
When you print an email using AOL Mail software, you may notice that the font size either appears too small or too large.
AOL Mail gives you the flexibility to adjust the font size and thus, the size of the print.
Note that these instructions apply to AOL 9.0 or higher.
If you have an old edition, follow instructions from the link specified under Resources.
Launch your AOL Mail software from the Start menu or desktop shortcut.
Log in using your AOL screen name and password.
Click "Settings" on the top bar.
Click "Font and Text."
Click the font type drop-down menu to choose either a larger or smaller font type than the current one.
Click the font size drop-down menu to choose either a larger or smaller font size based on your preference.
Click "Save."
Hope this helps
Internet
Browser Instructions
If
you open your email account using a browser, there is a very simple
way to increase the font. Font size options are located either under
"Tools" ("Options" or "Preferences"
then "Content") or "View" (text size) on your
browser's main menu. Change the font to a larger size, which may be
set by number or by selecting "Larger" or "Largest"
font from the list of options. You may have to click "Advanced"
or the similar option in the "Fonts" section of some
browsers to adjust the font properly.
Next, click "File"
then "Print Preview" on your browser's main menu. This
will show you how the email will look when printed. Click "Page
Setup" and deselect the "Shrink to Fit Page" option.
This will allow you to print the email at the new, larger font size.
Be sure to return your browser's font size to normal when you are
finished printing the email, or else all of your pages will display
with a larger font.
If
you use a non-browser email software program to view your emails,
insert your email contents into Microsoft Word (or a similar word
processing program) to print it in large letters. Select the entire
message from your email software then go to Word to paste the
contents into a blank document. You can then select the text of the
email and increase the size of the font. When you're done, print the
file as you would normally. You can also perform this action with an
email that you open inside of a browser.
