Washing Machines Logo
D
Dom Purtell Posted on Jan 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
General alarm shows on display yet the machine is clean how do I resolve this?
Eric Taylor
Level 3:
Master:
  • Master 590 Answers
  • Posted on Jan 02, 2018
Eric Taylor
Master
Level 3:
Master:
Answers
590
Questions
6
Helped
206192
Points
1556
When you let people know what type of machine it is then maybe we could help but go to the manufactures and download the user manual and check in the trouble shooting guide eric
3 Related Answers
Dane1234
Dane Ericksen
  • 25 Answers
  • Posted on Jun 29, 2010
SOURCE: eam3500 delonghi coffe machine
From page 21 of the owner's manual: Message: general alarm. Meaning: The inside of the appliance is very dirty. What to do: Clean the inside of the appliance thoroughly, as described in section 15. If the message is still displayed after cleaning, contact a service center.
Hope that all your machine needs is a thorough cleaning; it's not that difficult.
caroldon
  • 17130 Answers
  • Posted on Oct 19, 2011
SOURCE: My DeLonghi EAM3500 display "general alarm" and
It is best that you contact the customer care of DeLonghi and post your request. you can also register your product for support.
The power supply can be sourced after the price is confirmed as these are available only with their spares department.
click on;
http://delonghiusa.com/support/
mnwarfield10
mark warfield
  • 453 Answers
  • Posted on Oct 25, 2011
SOURCE: Machine is in General Alarm - cannot get the
sounds like a new motor is req... 07779933829 we can help.
Can anyone tell me what alarm OG6LNY means on a delonghi ecam 25.462b coffee machine means please
  • If your machine displays a general alarm message or a warning light indicated by a red exclamation mark please carry out the following steps:
    • Switch the machine off using the power button on the front of your machine, and wait for the shut down process to complete fully before the next step.
    • Plug the unit off.
    • Open the service door.
    • Remove the drip tray and grounds container.
    • Remove the brewing unit (infuser) by squeezing the two red <a href="http://despreserialero.com/juramantul-episodul-505-506-subtitrat-in-romana/">despre seriale</a>
      buttons either side of the 'Push' button.
    • Pull gently. If the infuser will not freely come out do not force it.
    • Clean the infuser using warm water once removed.
    • With the infuser still out of the machine, clean the inside thoroughly using a vacuum to ensure all grinds are removed. Pay particular attention to the area behind the grounds container.
Delhongi Magnifica. Why does my coffee machine suddenly show alarms?
This machine is frequently turning up here on Fixya with issues. Take it in to you local DeLonghi service centre and tell them to fix it for free.
My delonghi ECAM23.450 when turned on displays "heating up please wait" then nothing - sometimes it will show "general alarm" then nothing - the machine is clean and has not been used very often - any...
Check NTC sensor and heating element terminals. You should get resistance with multimeter or ohmmeter. NTC sensor should change resistance when you heat it up with lighter, finger or whatever heat source you have near by.
Condensor clean alarm will not shut off
To clear the alarm:
1) Press and release the "SET button four times. "cnd" will be displayed on the screen.
2) While "cnd" is displayed, press and hold the "SET" button. The display will show the number of weeks the refrigerator has been running.
3) While holding the "SET" button, press and release the ON/OFF button. The number shown on the display will reset to 0.
4) Release the "SET" key.
How can I reset alarm F21 on Bosch washing machine type WIM40?
Dear Sir,
it is requested you that we have a washing machine Type: WIM40 & RN # WAE20463tr/12 it has still showing error on display as "F21 alaram" Kindly resolve it or tell us solution that what will be.
Best Regards,
Imran Khan Nawab
4helpful
click on;
4helpful
2answers
Screen Alert: General Alarm What does this mean
General alarm means the machine has detected a serious fault. There is a section in the instruction manual that may help. If not, read on.
Persistent "General Alarm"
This means many things. If the transmission is not stuck, check the main boiler has not burnt out (open circuit). This happens when the thermoblock labyrinth runs dry and overheats, a common problem caused by leaks, limescale, milk blockages or water filter contamination. Replacing the boiler is the only fix, a difficult and expensive process, experienced fixers (or nothing to lose) only.
Transmission
If the transmission is getting stuck there may be obstructions, the lead screw may be worn or the limit switches could be faulty. If cleaning and grease on the screw/bearings don't help then replacement is a tricky job only for confident hands. Approach with caution.
1helpful
2answers
Eam3500 delonghi coffe machine
11helpful
2answers
My Delinghi eam3500 has come up with general alarm, I have cleaned the unit like it says but it is still not working, when it turns on it says warming up, but it tries to warm up for ages but nothing...
The general alarm message after the machine taking too long to heat up -in deed shows a problem to reach the correct temperature.
So there are a number of possible causes:
the 2 heaters (water/steam) the NTCs(temperature control sensors)
the tempearature overheat-fuses. In my case it was the (water-)heater itself. Be sure to unplug the machine from power supply befor opening!!!
First test then-do the heaters warm up??.....carefull if they do-they are hot!!! If one of them doesn´t warm up- Unplug again!...and then measure the resistance of this heater-If the heater is ok,it should show around 50-58 ohms. If it shows indefinite resistance the heater is broken and you have to exchange it.
In case of both the heaters showing the~50ohms you will have to check the thermal resistors/fuse/NTC.
For me the two forums below wer of great help for me...of course they are in german...but didn´t you wish to learn a foreuage anyway???
Good luck and best regards
Wolfgang
Ref,:http://www.kaffeevollautomaten.org/forums
http://www.kaffee-welt.net
Top General Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
How-2-Repair.com
How-2-Repair.com
Are you a General Washing Machine Expert? Answer questions, earn points and help others
