SOURCE: LG inverter Direct Drive 7kg
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
SOURCE: getting an error code OE
Hi Ged Lunny,
The OE error code means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
SOURCE: LG true steam inverter direct drive 9 kg f1479fds5 on a screen AE error what s happend
The AE error is indicative that there is a leak somewhere in the washer and it has triggered the flood protection device found at the bottom of the machine. What you should do is find out if there is indeed a leak. Try tilting it forward and find out if water will run out. If you can see water leaking from the water, call a repairman!
