SOURCE: Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
SOURCE: New Motherboard & Processor not working
Usually this symptom has to do or with memory modules with problems or the VGA adapter (integrated) could be damaged. First try to reset the BIOS of *********** taking out the battery and using the reset jumpers informed in the Mother Board manual. Then put the battery and the jumpers back to the factory default position and try again.
If this doesn't work, try to plug the power cord to another 220V as the ground could cause this type of problems.
You can also try to install another VGA adapter to check if you receive the VGA signal in your monitor.
Hope it helps...
Please tell us about your progress.
Best regards
Eduardo
SOURCE: i need a new processor and motherboard for a dell dimension 3000
As posted by Smithbrother, you can't just put any motherboard in a Dell--the case and motherboard are built for each other. You would be better off buying another computer. A new motherboard means a different processor (like you want). This means a different, higher speed memory.
You can have a system built by a local computer person or browse some of the sites (you can go to Dell for some real deals--as well as other company sites).
Any new system will not have "only pci slots." The new boards will have PCI-E slots for your video, but will also have some PCI slots for expansion.
Cost? That's hard to say. I have to do an estimate for each of my clients depending on just what they want.
SOURCE: processor upgrade
Yes you can :
http://forum.notebookreview.com/showthread.php?t=354059
here is another video on it:
http://www.truveo.com/Acer-Aspire-4315-CPU-and-optical-drive-upgrade/id/3529273416
SOURCE: What CPU supports Abit Fatality F-190HD motherboard?
The following CPUs were tested with it.
http://www.abit.com.tw/test-report/fatal1ty-f-i90hd.htm?1
Since your CPU was released after the board was released it might or might not work.
The CPU FSB is 800 and the board supports it so it could accept it.
Here is the motherboard specifications
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=Fatal1ty+F-I90HD&fMTYPE=LGA775&pPRODINFO=Specifications&fSEARCHTEXT=Fatal1ty%20F-I90HD
