Not sure what unit you have or if electric start...but elce start then disconnect the battery for 10 minutes and re-connect. Clears the code on generac and some other manufacturers.
former generac rep.
Hope this helps.
SOURCE: from cold start my renault megane starts to over reving
Having exactly the same problem with my megane and the mechanic just charged me £687.00 and does not know what to do!!!
SOURCE: i have a 1988 mk 2 golf when i start the engine
sounds like the thermostat stickng as when engine gets cold the choke will start workin again, causing the over reving or your electric fan is on all the time "over cooling" the engine
SOURCE: F250 Diesel engine won't start in cold weather
check your glow plug relay! located on the right side head
SOURCE: TPM is alarming every 30
Cold weather causes air to condense and air pressure to be reduced, causing your tires to read low pressure to the TPM. Check and fill all your tires to your recommended vehicle inflation pressure, to stop the TPM from alarming you every 30 seconds.
SOURCE: saab 900 engine running erratically & smell off petrol
The idle speed in this car is controlled automatically by the computer (ECM), the problem is that the valve that the computer operates gets dirty from gas fumes and cylinder backwash and this causes the symptoms you have, it is a common problem and the reason that all manufacturers have gone to automatic throttle control and eliminated the Idle speed control valve, it is fly by wire system. Do the following and it should clear the problem up, if not you may need to see the dealer for further testing. To correct this problem Buy a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, NEVER USE CARB CLEANING SPRAY, IT DESTROYS THE ANTI-STICK TEFLON COATING, spray it into the air intake through the throttle body of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is now clean, if you continue to have the idle speed control problems you may need to seek the help of a professional.
