SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display.
This is apparently a failure to drain properly.
I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains.
Turn off the water supply to the machine.
Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water)
Remove the drain hose from where you have it going to.
Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water).
Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum.
Use some pliers to pinch the steel spring that clamps the hose in place and remove.
Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on.
Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks).
Plug it in, turn on and that for me was it.
Job Done.
SOURCE: hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
SOURCE: cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Thanks.
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
