Washing Machines Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Washing machine tripping RCD
Bosch Exxcel 1400 Express WFX2867GB/06. My washing machine starts cycle and then trips mains RCD after its filled with water. After re-setting RCD does the same thing again immediately. After emptying water from drain and resetting program will start cycle and fill with water and then trip. What's wrong?
Anonymous
Level 2:
  • Expert 44 Answers
  • Posted on Jul 30, 2009
Anonymous
Expert
Level 2:
Answers
44
Questions
Helped
15107
Points
123
Electrical short in m/c.could be heating element. regards
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
1helpful
Bosch EXXCEL 7 1200 trips the RCD before even starting
Sounds like you keep the washing machine in an environment which is either damp or not well ventilated.if condensation or moisture finds it's way onto the main control panel of said machine it will cause short circuits which will then trigger the house protection circuits.quick solution is to gain access to the control panel by removing the top after disconnecting power supply.then using a hair dryer over the circuit board panel for about five minutes, reconnect power and keep hands away from any internals and try to repeat the problem.if it still trips it could be a faulty relay or that the main pcb has failed.have you recently experienced local thunderstorms as this is another possible reason for damage to pcbs.
1helpful
Bosch exxcel 1200 tripping the RCD when I set timer for a wash and press the on button, any ideas?
I would say the heater element has blown this would cause main trip switch to trip
Bosch exxcel f01 code comes up after switching on
Question?#$@???
Exxcel 1400 express with the number E-Nr. WFX2867GB/10 FD 8410604749,
The last time I used the machine I interrupted it while it was washing and thereafter its stopped working. When turned on it will collect water and detergent but will not turn or wash.
What do I do????
5helpful
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
2helpful
2answers
Bosch Excell washing machine programme fault
This video will show you how to replace the Bosch washing machine heating element and thermostat with step by step guide on the process
5helpful
3answers
USER MANUAL FOR BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
just go a bosch washing machine exxcel 14 express cant get it to work can anyone help i dont have the user book my email is [email protected]
Top Washing Machines Experts
john h
