Always tells to change paper size don't know how
The wireless office printer /copier/scanner/ fax machine from the IJ Scan Utility Canon Pixma mx490 setup thanks to outstanding connectivity choices and the ability to put a lot more places with the printer than ever before? S 30% decrease in size compared to earlier variants of MX. With Google Cloud Print and AirPrint, you can print wirelessly from virtually anywhere around the office from your appropriate smartphone or tablet computer. It? Loaded with time-saving features, including a fully integrated automatic file feeder holding up to 20 sheets. And the optional XL ink cartridges also recommend you can print longer before your cartridges need to be changed. Using a 30 percent decrease in size relative to its predecessor, Canon Pixma mx490 setup Office All-in-Onejet Printer provides individual printing, scanning, copying, and fax capabilities in addition to wireless connectivity without sacrificing a big amount of your useful desk region.
SOURCE: I am trying to print
Check your printer preferences. Check inside the printer if it has some paper jam.
Cancel all your printer jobs, turn off the printer - Turn on the printer and try again
The tray itself should have tabs on the side telling the type of paper look at those and see if there is anything broken off.
SOURCE: Ricoh Aficio 1075 - Change paper size on TRAY 1
you need to set the dial on the back of the paper tray
SOURCE: i want to print an invitation, the paper size is
Most printers the paper size can be adjusted through the properties display.
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
