SOURCE: Engine Fuser Low Heat Error
Basically the error message is telling you the printer cannot keep the fuser temperature at the proper temperature (too low). It could be a lot of things but typically it is due to a fuser assembly gone bad.
SOURCE: ML 3561ND engine fuser. low heat error??????
If you have annother tonner cartridge, (the old one will do)fix it and see if it works. If not there might be a component faillure related to the Fuser Unit. Also check for any Jam in the Pinions(Sometimes Samsung Laser Displays wrong MSG.)
there is a 2 wire device (thermistor) that rests against the fuser roller to measure the temperauture. if the fuser is getting quite hot, suspect the thermistor to be either dirty (remove and clean it with alcohol) or defective. if fuser not getting hot, then suspect burned out fuser heater (look inside fuser roller for a long light bulb).
I have the same probolem with the Samsung color laser printer clp-510. I get the "engine fuser low hear error"
What can I do?
How do I get the diagnostic software to try that too?
SOURCE: low heater error
I bought another second hand one for € 40,00 and replaced the unit. It's just 5 screws and on we go again.
I have a CLP 500 and bought a CLP510N. The units are the same. unfortunately not all parts on the machine are the same, but for now mine works again.
