Sewing Machines Logo
M
Mary porretta Posted on Dec 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an elna 3210 3230. Thread keeps breaking, stitch does not interlock. Help. Mary Poretta
R.A. Ellis
Level 3:
  • Elna Master 12,731 Answers
  • Posted on Dec 31, 2017
R.A. Ellis
Elna Master
Level 3:
Answers
12731
Questions
Helped
2613443
Points
59176
Sounds like possibly more than one problem.
Why is my thread breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Sewing Machine Problem 1 Thread Breakage
If the top thread is not picking up the bobbin thread, it's possible the machine has been knocked out of time. Did the needle hit something or break recently? You can search for sewing machine timing or take it for service.
5 Related Answers
Anonymous
  • 323 Answers
  • Posted on Jul 16, 2008
SOURCE: I have an old (about
Thread the needle last.Thread the lower looper first.
sewman7
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Elna SU missing stiches and breaking thread
it sounds like the needle hook timing is out. You need to get the needle in the lowest position and measure the gap from the needle to the hook point on the bobbin shuttle. It should be 1/4". You will need to remove the foot and foot plate to be able to see. I use a 1/4" drill bit as a gauge. If you need to adjust it, you will need to remove the free arm cover to the right of the foot and loosen the 2 allen head screws that hold the drive gear. Adjust the gap, tighten the screws and retry. Usually if the needle catches the thread to early, it will make a bad stitch and the upper thread will break. If it catches to late, it will make thread loops and the machine will skip stitches. Good luck, these are a good machine and worth fixing. Phil
Anonymous
  • 334 Answers
  • Posted on Jan 18, 2009
SOURCE: CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Anonymous
  • 4 Answers
  • Posted on Jun 20, 2009
SOURCE: My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Anonymous
  • 53 Answers
  • Posted on Jun 07, 2010
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
1helpful
Thread breaking on elna lotus tsp
When it stitches, does appear the top thread is tighter and pulling the bobbin thread up? Pay attention to what is happening before the thread breaks. Sew slowly and manually turn the handwheel. Where does it break? What are the symptoms before it breaks? Does it fray/shred at the needle eye? (The thread is not advancing through the needle eye properly and is actually being shredded, could be the needle has a sharp spot or the needle eye is too small for the thread. Coarse fabric will also shred thread.) Do you notice the top thread getting tighter and tighter and then finally popping? (The thread is being held back somewhere in the thread path {misthreading'--happens to me when it gets wrapped around the spool pin or a thread guide.)
Suggest removing the top thread completely from the machine. Install a brand new needle that is the appropriate size and type for the thread and fabric. Remember to ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Adjust the top tension until the top and bobbin threads meet in the middle of the fabric.
https://www.howcast.com/videos/512591-why-does-my-top-thread-keep-breaking-sewing-machine
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
1helpful
I have a elna 664 pro overlocker. The thread keeps on breaking. I have even serviced it. It came back. Worked a while and it started doing it again. Works a few stitches and the tread breaks
Hopefully, it was recently serviced. Take it back and have the technician take another look at it. Do NOT unthread it (just clip the threads below the thread tree) when bringing it in so the technician can verify it is threaded correctly and also see where it may be hanging up.
2answers
Elna expressive 900 thread breaking (although not really) and bunching up on underside of fabric ESPECIALLY when doing embroidery. Why?
try using gutermann thread and needle according to your fabric thickness and tension dial must be 3-5 and bobbin thread hold the end of the thread and bounce to see how loose the thread is cos if it releases too easy you need to turn the screw on the casing just a little see how you go
1helpful
Elna 2005 I don't have the manual. Which setting is for the stretch stitch?
A special stretch stitch is not required to sew stretchy fabric. All one needs is a zig-zag that is wide enough and close together enough to allow the fabric to stretch without breaking the stitching thread. (Test it on a piece of scrap fabric you are using, give it a good tug and see if the thread breaks.)
NOTE: be sure to use a ball-point needle. A sharp needle will tend to cut the fabric threads and your stretch fabric will eventually develop holes and runs commonly found in knits.
There doesn't appear to be a manual for your machine, however, you can usually find a manual close to your machine model and the instructions will be similar enough to suffice. Perhaps you will find one with instructions for sewing stretch fabric:
ELNA Other manuals
Elna 1500 sewing machine stitches dont interlock
it's possible that the machine is out of time
you can check with youtube or fixsewingmachines.com for video's on the problem
1helpful
I need a manual for an Elna Special machine. I am not sure of how to thread the machine properly and I don't know what one of the dials on the front of the machine does.
There is also a Yahoo group for Heirloom Elna owners which this model is.
You can find threading diagrams and manuals at www.sewusa.com. the supermatic will be closest to your Special. This webpage has images of threading the bobbin; all Swiss made Elna's have this wonderful top loading bobbin system and they are great. Important: use Elna bobbins, they have holes on the TOP ONLY. When you wind the bobbin, ensure the thread winds evenly by nudging the thread with your finger tip, keep the thread under tension as it winds by placing the handle of your scissors onto the top of the thread reel. Cut the thread, then place the bobbin into the bobbin case, holes upwards. The bobbin will turn anticlockwise as you pull thread from it. Follow the directions from the threading diagram, you need to "click" the thread into the tension spring. Now thread the top thread through the marked locations in the diagram. Hold the end of the thread as it comes from the needle and manually turn the flywheel to lower the needle down and up once to catch the bottom thread and bring it up to the needle plate.
ALWAYS hold both the two threads at the back of the needle plate when you start sewing, really important. I tally_girl.jpg You will have a knob with numbers going from -4 to 4, this is your stitch length dial. The negative numbers are "Reverse" normal stitch length is 2.5. The white knob is stitch width when the needle swings from side to side. Straight stitch would be zero, and then higher numbers for zig zag etc. The little wheel gives you different needle positions. And the metal slide at top of case is the reverse lever.
Hope this helps you a little. Early Elnas are all very similar and wonderful machines to use.
I have an elna overlock Pro 5DC, which I bought new years ago. The dealer went out of business, and with her the repairman who knew Elnas. When mine developed a problem, I had it serviced by an all-brand...
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Having trouble threading the needle, thread keeps
You might have either a tension problem or a bent needle. Try replacing the needle and then re-thread the whole thing and see if that helps. The majority of the time when I am having thread-breaking issues, once I replace and rethread, it is fixed. Hope this helps.
8helpful
Oct 27, 2008 • Elna 1010
Top Elna Sewing Machines Experts
Mike Cairns
Mike Cairns
SmartAviator
SmartAviator
Ngoro
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
