Microwave Ovens Logo
Christopher Madikizela Posted on Dec 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
SAMSUNG MICROWIVE DISPLAYS -SE- - Samsung Microwave Ovens
William Miller
Level 3:
  • Samsung Master 9,179 Answers
  • Posted on Feb 04, 2019
William Miller
Samsung Master
Level 3:
Answers
9179
Questions
Helped
4479291
Points
21747
See http://www.microwavecontrol.com/samsung_se_error.htm
Mr.Mike
Level 3:
  • Master 580 Answers
  • Posted on Feb 02, 2019
Mr.Mike
Master
Level 3:
Answers
580
Questions
0
Helped
195879
Points
1906
Hi, there try this
SE or 5E Error Code appears when any keypad button remaining pressed for more than 10 seconds.
To try to clear the error code, please perform a power reset by turning off the unit by unplugging it from the wall for more than 1 minute.
After power reset is performed, plug the unit back. If the error code is cleared, set the clock and use the unit.
If the error code is still there please contact our Call Centre (Samsung Customer Care) so they could provide further support.
https://www.samsung.com/nz/support/home-appliances/error-se-or-5e/
good luck
https://www.6ya.com/mr.mike
Samsung OTR microwave displays TE and won't work. What does this mean?
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
Samsung OTR microwave displays TE. What's this mean?
2answers
Why does screen say SE
SE = Sensor Error, its reported that it could be components bent over, and touching each other on the PCB behind the keypad.
You need to be a fair bit mechanically savvy to attempt a repair, and remember to Unplug it before you do! :-)
Samsung microwave mw73e
Have a look in the user manual: http://downloadcenter.samsung.com/content/UM/201108/20110802174701427/MW73E_ELE.pdf
If the answer is not in there, contact Samsung technical support.
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Do you have glass microwive model bmo 700 (17 lt)
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
18helpful
3answers
It displays SE and nothing works.
SE error means you have a shorted membrane keypad.
With your model number I can detail your options.
Manual for samsung MW73E
My oven displays "-SE-" and is not operationg. please guide me.
Nilesh Soni,
[email protected]
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
