SOURCE: Hitachi Cordless Impact Driver gearing problem
The speed shift slider switch wasn't lined up correctly when the unit was reassembled.
Unfortunately, you going to need to repeat the disassemble/reassemble process once more.
I've been there. It doesn't take much to be out of alignment. Set everything to the lowest setting (clutch, speed) and take your time.
Best regards
Mike
SOURCE: Panasonic EY7540 impact driver. Does not go into reverse on 1st
EY7540 14.4 volts. Both batteries were fully charged. Operating the driver in various positions would result in the Red battery charge and temp. light coming on and the operation of the driver would die. Pointing the driver up, it was OK. Pointing it down it failed. All connections and solder joints were checked. All joints in the battery cct board were checked. By the way I am an electronic technician. Any ideas?
SOURCE: my dc825ka dewalt impact drive will turn forward
Sounds like a problem in the Mechanism assembly. You have the option to attempt to fix it yourself or contact DeWalt and take it to a Local Service Center, you can find your local service branch at www.dewaltservicenet.com. From this website you can also order parts. Here is an exploded view and parts list of your tool.
http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=70578&typeId=16779&documentId=36008
Hope this information is helpful to you, if so, please rate me. Thank you.
SOURCE: I don't believe I have
here is a link of IR impact in 3/4" drives
http://www.google.com/search?q=Ingersoll+Rand+-+Rand+IR+-+252+3%2F4%27%27+Heavy+Duty+Air+Impact+Wrench&rlz=1I7GPCK_en&ie=UTF-8&oe=UTF-8&sourceid=ie7#sclient=psy&hl=en&rlz=1I7GPCK_en&source=hp&q=Ingersoll+Rand+-+Rand+IR+-++3%2F4%27%27+Heavy+Duty+Air+Impact+Wrench&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=eb878a5eb62da218&biw=998&bih=432
