SOURCE: drum wont empty...have checked pump,
It obviously is related to the pump and outlet hoses.
If it is a tap in waste then check for obstruction there,
Remove drain hose completely and run water though it to make sure it is fully clear.
Check inside the pump itself for any obstruction , if you are satisfied that every thing is o/k, then as a last resort, fit new pump.
Plz leave feedback for this solution.
Thanks.
SOURCE: Flushing knob on a C2 Theford cassette porta potti hard to turn
Hi! Spray blade which closes holding tank with silicone spray. Make sure spray goes under lip of sealing ring. Also spray around holding tank actuator knob allowing to penetrate underneath to shaft. Don't use a silicone grease as this will gum up the works. If you can't get hold of a light silicone spray try using household type silicone polish intended for furniture. Wipe off any surplus as only thin film required.
John Long
SOURCE: nothing happens when I press the start button.
here is a list of things it could be. pull spark plugs check compression. all cylinders need to equal each other within five percent, and be over 100 lbs of compression. I don't know the year model but, some gp1200 comes with a security key pad. click here for a link to Yamaha, for the owners manual. it will give detailed instructions on how to reset code. last find the starter solenoid I have attached a picture.in the picture it has a number one marking the image. the discription at the bottom says starter relay assy A quick test of the starter is to jump across the leads. You need to be careful it will arc. best thing to use is a short screw driver. use the metal shaft of the screw driver to connect both threaded connectors on top.
SOURCE: the flush pump has a leak, can this part be
hello. yes. Go to this link to order
http://thetford.com/?TabId=345
Joe
