Dryers Logo
C
Chris Zambas Posted on Dec 31, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I reset the button on my fisher& payment dryer. It worked for a short while and stopped heating again. What next?
vince
Level 3:
  • Master 2,530 Answers
  • Posted on Dec 31, 2017
 vince
Master
Level 3:
Answers
2530
Questions
0
Helped
747408
Points
8845
Check to see if lint build up is causing your thermal switch to trip. Pull out the lint trap and you'll see 1 Phillips head screw behind where the lint trap normally sits. Remove the screw, and you'll feel the circular plastic piece the lint trap sits in become loose...pull this round piece out of the dryer from the bottom. If there is a lot of lint behind this circular plastic piece, that's probably what's tripping the heat sensor. Vac it out. Gently feel around the circumference of where you removed the piece to see if the fine mesh lint screen has any holes (if it does, it may be blowing lint into your exhaust and eventually clog the vent to the outside). If the mesh is torn, I assume that larger circular piece needs to be replaced at some point in whole or part. From what I can see, the design of the lint filter and trap is ....****. The system allows lint to enter the area where the heat sensor sits.
The short term fix is to vac out the sensor area regularly and that will keep the switch from tripping, if that is your actual problem.
this was answered by someone else a year or so ago on this site thought i'd pass it on.
Hope this works.
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Aug 21, 2007
SOURCE: Dryer runs for 5 minutes then stops
look in the vent line for a small disk shaped overload with two wires coming out of it. it may be bad. also check for a lint build-up in the exhaust line out of the blower. check the damper outlet going out of the house for a build-up of lint.
A
Anonymous
  • Posted on Jun 04, 2008
SOURCE: My Bosch Condensation dryer (W2L 5400) won't heat up -- can't find the reset button
you need to remove the centre metal plate,after powering off the dryer. The small red reset button is on one of the black plactic connects on my model (WTA4408)
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 19, 2009
SOURCE: where is the reset button on my fisher paykel dryer
reset? just unplug it for 5 miinutes.
Anonymous
  • Posted on Nov 08, 2009
SOURCE: Fisher & Paykel Auto Sensor Dryer stops & beeps constantly
Hi emkboyce
my Fisher Paykel auto sensor dryer keeps stopping and beeping, i have to stop it and and re start.
I had the same problem. I took it off the wall and vacuumed up all the lint from everywhere including around the back and including taking off the back and vacuuming everything I could reach inside. I then used a damp cloth to get rid of the rest of the lint/dust.
I thought I was wasting my time but guess what, the problem has gone.
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Oct 10, 2010
SOURCE: there is no heat, when i pushed the reset button
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Fisher pakel will run wont heat have hit reset button and will work fine for a couple of loads then does the same thing I hit reset button and will work again
9 times out of 10 the element is bad, it sounds like you have the true top load dryer. in the cage that has the reset-able tstat, there is two element packs. half of it is burned, and it is heating alot near that tstat, making it trip. Take out the element packs, and let me know how it turned out.
1helpful
Heats when unit is not on
Same thing just happened to my DEGX1. I took it apart and one of the heating elements had broken and fell to the bottom of the metal case. I think it was creating a short to ground and making it heat. I removed the broken element wires and attached them back best I could and did a test run with no problems. It is not heating when off now either. searspartsdirect.com had the elements for $67 so I ordered a set and will replace both of them (part #395583). My dryer is only 4 years old and 3 weeks ago the driver belt broke. Irritating they can't make them last any longer these days.
3helpful
First the dryer stopped heating, then when the reset button was pushed it started drying again, but now the heat will not shut off without unplugging the dryer
This is a situation that you need to be very careful with. It sounds like you have a grounded heating element. If this is the case, then the current can be running through the dryer's frame and can cause electrical shock. Keep the dryer unplugged and check the heating element for continuity. If it has none, replace the heating element. BE CAREFUL. Hope this helped and best wishes.
38helpful
3answers
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Burning smell after hitting the reset button
the lint may have moved into the motor/ or other areas, clean the unit again and have another inspection, checking for burn't wire etc.
Not heating
The reset button needs to be replaced.  Once it has tripped, it loses it's setting and will trip at a much lower temperature.  This is a standard procedure that LG is telling all their techs to do.
1helpful
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Top Dryers Experts
john h
