Computers & Internet Logo
A
Anonymous Posted on Dec 30, 2017
Hi there I have set up my Amazon echo and when I lock my apple phon it goes into sleep mode, any ideas why?
ekta singh
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Apr 30, 2019
ekta singh
Contributor
Level 1:
New Friend:
Answers
27
Questions
0
Helped
2755
Points
87
Hi, visit there and ask you all problem with your Apple device to apple customer care https://bit.ly/2P5lXNm
5 Related Answers
Anonymous
  • 160 Answers
  • Posted on Mar 25, 2008
SOURCE: Monitor goes into sleep mode after a few seconds
Click on Programs --> Setting --> Control Panel
Choose the "Power Options"
in the "power schemes" Choose the Turnoff Montior, turnoff HDD, system standby
and system hibernate as "Never" in each combo box and clikc on apply.
repeat the above process for every power scheme options
Let me know if your problem is solved and rate me as FIXYA!
Anonymous
  • 298 Answers
  • Posted on Aug 30, 2008
SOURCE: sleep mode
turn off the timer, it should have a button on the remote for that.
Andrew Perrong
  • 285 Answers
  • Posted on May 24, 2009
SOURCE: Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
Anonymous
  • Posted on Aug 11, 2009
SOURCE: iphone does not ring on sleep mode
1. File manager in ipcsuite
/System/Library/SystemConfiguration/PowerManagement.bundle
2. Find the file:
com.apple.SystemPowerProfileDefaults.plist
Then rename it to:
com.apple.SystemPowerProfileDefaults.plist2
3. Reboot your phone
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Mar 07, 2010
SOURCE: monitor goes directly to sleep mode
More likely to be power supply problem due to bad caps, you need to open it up and look for caps with bulging top, post back what you see so we can guide you furhter. See example of failed HP monitors and other due to bad caps: http://s807.photobucket.com/home/budm/allalbums
5answers
How do I link Apple Music to echo
Turn Bluetooth on and pair with your echo
How do you turn off the auto shut off on the CANON MP25DV
You can't, it's a 'feature', set for every 7 minutes of inactivity. However.....
I don't think you can turn off sleep mode. However, after the calculator goes into sleep mode, to return to where you are working just press the C/CE key (red key bottom left). The calculator will return to where you left off.
See all 12 answered questions - Amazon.com: Customer ...
www.amazon.com > ask > questions > asin
I hate Canon's automatic shut off feature in some of its models. Answer: Hi! The Canon MP27DII calculator will go to sleep after approximately 7 minutes ...
How To Turn Off Sleep Mode ' Canon MP25DV Support
www.helpowl.com > MP25DV > Troubleshooting > tur...
Oct 11, 2018 - Canon MP25DV - would like to turn off the automatic sleep mode af. ... The machine is design with energy saving mode, Press <Power button >. ... and easy-to-use keys that automatically perform complicated applications, ...
SOLVED: CANON MP25DV TURNS OFF EVERY 7 MINUTES ...
www.fixya.com > ... > Canon
Aug 10, 2018 - CANON MP25DV TURNS OFF EVERY 7 MINUTES. HOW TO STOP THIS? - Office Equipment & Supplies.
3answers
Setting up Apple music on Echo dot
You Can Now Ask Alexa to Play Apple Music with Amazon Echo Controlling home by voice is going to be a lot of fun. Amazon Echo, a nine-inch black cylinder, is such a smart speaker that connects to the voice-controlled intelligent personal assistant service Alexa. You can use Amazon Echo to do certain things like play music, set alarms, make to-do-list, order items from Amazon, and control a smart home. To play an audio? It becomes extremely simple when having an Amazon Echo. Instead of tapping here and there on the phone, you only need to hook up your account to the Echo, then simply ask Alexa to play whatever you want. Unsurprisingly Echo includes Amazon's own music services, as well as some others such as Spotify, Pandora. So what about other streaming services such as Apple Music? Does Amazon open to have Apple Music on the Echo? Is it possible to stream Apple Music to Amazon Echo? The post would answer these questions and show you how to play Apple Music on Amazon Echo by asking Alexa.
Apple Music does not come to Amazon Echo
Amazon Echo is capable of playing music from other sources and streaming music from various services, including Spotify, Pandora, iHeartRadio, and Amazon Music. How about Apple Music? Unfortunately there is no support for Apple Music at the moment.
When will Apple Music come to Amazon Echo? According to a report from Bloomberg, Amazon's Dave Limp was quoted as saying, "We'd love to have Apple, but they're not super big." Perhaps Amazon thought Apple Music is not quite big enough to consider integration even though Apple Music has already racked up more than 20 million paid subscribers in two years since announced in 2015.
Use the Amazon Echo as a Bluetooth speaker to Play Apple Music
Although Apple Music is not native supported by Amazon Echo, Apple Music subscribers can still stream songs through the device, it's just that they'll need to pair their iPhone or iPad to the Echo and stream it from their phones instead. For people who also want to play music from iTunes library with Amazon Echo, they should also make it via Bluetooth. In this way, Amazon Echo is used as a Bluetooth speaker which does not make it unique.
Here are the steps to stream Apple Music on Amazon Echo via Bluetooth:
  • Go to Settings. Then, tap on Bluetooth and toggle the button to the on position.
  • You'll now see your Amazon Echo device listed under My Devices. Tap on it and it'll pair with your phone or tablet.
  • Navigate to your Music application where your Apple Music are accessible and start playing them.
Now, Apple Music songs should be heard coming from your Amazon Echo device instead of your mobile device speaker.
Link Apple Music to Alexa on Amazon Echo Pairing your device with the Echo using Bluetooth and selecting it as the audio output is an option to stream Apple Music from your iPhone. It is not a bad solution. But if what you intend to do is get Apple Music on Amazon Echo by using Alexa, then uploading Apple Music songs to Amazon is a great way. You can upload your Apple Music collection to your music library on Amazon and then stream the Apple Music through your Alexa device.
Before importing Apple Music to Amazon, we still have one thing to solve. That is, removing DRM from Apple Music or the songs from Apple Music could not be recognized and uploaded to Amazon successfully. Here we use Apple Music Converter to convert Apple Music tracks and playlists to plain DRM-free MP3 to walk you through.
$39.95 Buy Now (Mac) $39.95 Buy Now (Windows)Click the + button on the top or anywhere on the center to open the Add window. The Apple Music converter detects the whole iTunes music library automatically, so that you could simply select any playlist you saved or any track you prefer, then press OK to confirm.
The chosen Apple Music songs are displayed on the main panel of the Apple Music Converter. Click the Gear button on the top right to open the Preference window where you could set the output format, audio quality, conversion speed and the way to organize the output file. For example, choose MP3 as output format, 320 kbps as output audio quality and 20x conversion speed.
After pressing CONVERT button on the bottom, the Apple Music songs are being converting to MP3 at a very fast speed with high quality one by one. The output folder destination can be found by History > Folder. The songs from Apple Music are now DRM-free and could be able to upload to Amazon for playback via Alexa.
Skill to Stream Apple Music on Amazon Echo with Alexa
Upload the converted Apple Music songs to My Music on Amazon from your Mac or PC, when finished, you can ask Alexa to play your Apple Music songs on Amazon Echo and control playback with simple voice commands.
  • Run Amazon Music app on your PC or Mac and log in your ID.
  • Drag and drop files from the folder where stored the converted Apple Music songs into the Upload selection.
You can see uploaded music, and music that's uploading, by clicking the Uploaded filter in the left navigation sidebar. Once the Apple Music songs are imported to Amazon Music, you can play them on Echo or Echo Show speakers with simple voice command via Alexa. Speak "Alexa, pause" or "Alexa, next" and the music will pause or skip to the next song. You can also ask for Alexa to play music by genre, decade, mood, tempo, activity, and even lyrics. Amazing!
7answers
Setting up echo dot
hi roger.
see if this helps you out.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
or if you need more help go to this link.
Setting up echo dot Google Search
1helpful
5answers
How do i setup my amazon alaxa echo dot
There are Many People in the 21st Century are Wanting Some Difference Things Who Change their Life. The Amazon Echo Dot is one of those things Who Change the Human Life through the Voice Search. It is the Product of Amazon that is Coming in the Market to Make the Human Life Perfect. Amazon Echo Dot is a Speaker that is Used in Amazon Alexa. After Purchasing the Echo Dot, Many Peoples are Doesn't Know to Setup Amazon Alexa so For It You Have to Visit Our Official Website.
Whenever I step away from my Macbook Air (running 10.5.8) and it goes to sleep, when I come back it says that it tried to shut down Firefox but could not. Then I have to go through several steps to cancel...
I would check the energy saver settings under system preferences and see if it is set to go to sleep after a period of time. Also check the schedule button under energy settings to see if there is a scheduled sleep setup. Hope this helps
54helpful
13answers
Iphone does not ring on sleep mode
2. Find the file:
Then rename it to:
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
