SOURCE: DSC-W35 file error
It sounds like the memory stick would be full why not format it and limit your number of pictures to its capacity. Download pictures to your PC to have more space.
SOURCE: Internal memory
delete all data from ur internal memory or transfer all data from internal memory to ur memory stick. message will stop displaying
SOURCE: duracell usb memory stick
Unlocker might fix this:
http://www.softpedia.com/get/System/System-Miscellaneous/Unlocker.shtml
SOURCE: Janome MC 10000 with Easy Transfer using jef files
Try saving your Monogram Wizard design to your computer. Then open Easy Edit and Import the design using the drop down menu under File. Manipulate the design and then send it to the machine using Write designs. You will have to make sure the design is going to fit in the hoop correctly before you save it to .sew in the Monogram Wizard program. On the save screen... near the bottom there is a box about turning the design sideways and this is often the problem. Will be glad to talk more. [email protected]
SOURCE: My usb intelligent stick installs ok and shows
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
