Question about Razor Health & Beauty
Razor does not work...runs but too low to the foil to shave Ron
SOURCE:
Buffalo12980
  • 625 Answers
SOURCE: Loose Cutter Block
when you remove the cutter block is there a white nylon fixture atop the vibrating mechanism? this nylon piece snaps on the vibrating rod and the cutter snaps into the nylon fixture.
Posted on Sep 07, 2007
SOURCE: No close shaves
I've replace the cutting surfaces and the thing just won't cut.
Posted on Sep 02, 2008
  • 10 Answers
SOURCE: The razor head comes loose from the two arms.
The one piece motor drive which also contains the shaver head in the Braun wear out. They can be replaced by yourself or a shaver tech. A good place for parts, http://shaveroutlet.com/.
To disassemble the 7000 Series Braun shaver.
Disassembly of the 7000 Braun shaver is basically the same as the 8000 series Braun shaver listed below. The 7000 is actually easier to disassemble as the plastic is much thicker and the bottom socket cover pops right off as there are less tabs and they are bigger.
To disassemble the 8000 Braun Series shaver.
Remove the plastic cover on the bottom that covers the corded socket. Be careful, there are a total of two tabs on the short sides and four very small tabs on the long sides. I usedmy fingernail to create a space big enough to insert the corner of a credit card in the center of the long side opposite the blue light indicator, then gently removed the cover. Using a screwdriver could damage the plastic.
The two sides then pop off, they only fit on their respective side when replacing. Don't lose the two small black seals on the top of each side piece.
There are a total of four screws holding the body together. Remove the screws, using the proper flat blade or torx screwdriver. The shaver will then split into. You can then remove the the Motor Drive Unit and the separate circuit board with the batteries.
This would also be a good time to clean the goo buildup from around the shaver head.
Assembly is the reverse of above. The Motor Unit will only fit in one way, there is a flat side and a angular side. Be sure the pin for the trimmer is placed in its proper hole, or it won't extend.
Posted on Aug 27, 2009
  • 1273 Answers
SOURCE: I dropped my 8985 braun and it will no longer
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Posted on Dec 04, 2010
brector3
  • 1636 Answers
SOURCE: FS790 Remington triple foil razor
The model is F5790. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-sp-390-foil-and-cutter-set.html
Posted on Apr 16, 2011
Accidentally cooked with foil paper. Now my microwave oven is sparking. How can I fix it?
You could have burnt the foil into the bottom of microwave I would take a box razor and shave the area till there is no more foil melted in the bottom
May 07, 2014 | Samsung MU3250W Microwave Oven
What is an electric shaver?
Not like shaving razors, electric shavers work by shearing the whiskers, the hair enters the perforated metal heads of the shaver and is cut by the moving blade inside.
Feb 06, 2013 | Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Bought a Braun series 3 razor (#340 wet and dry). It hardly shaves the whiskers but it really messes my skin up. ( I was using a Norelco which did a pretty good job) I think there is something wrong...
You should be able to run your finger over the foil mesh on the Braun shaver to feel if there are any rough spots causing the problem you describe. If there is damage you may also be able to see it.
It could also be that the Braun shaver simply does not agree with your skin type. There are many people who are sensitive to different kinds of shaving methods. Foil shavers like Braun may not be the type of shaver for you
Apr 04, 2017 | Braun Syncro 7680 Electric Shaver
Remington es1000
The Remington ES-1000 was probably the best slot-head shaver ever made by Remington. I cannot believe that the market demand was so low as to prompt a cancellation of production. I believe that the production run was limited to about 4 years or so. I have 8 of these shavers and keep a couple old Remington slot heads around as well. The ES-1000 was not perfect. The batteries were way too small and stressed so battery life was poor.You could not buy individual blades as you could with past Remington slot-head units.Also, the edge of the head was too exposed and sharp and when used for body shaving would tend to cut the skin.Slot-head shavers are superior for body shaving and for skin that is suseptible to shaving bumps.They are also great for young men that are prone to ingrown hairs.My guess is that the Norelco 3 head has taken it's place. Those shavers actually use 3 small slot heads. Rumor has it that shavers.com is trying to have a new slot head manufactured in Asia.
Dec 05, 2007 | Remington ES-1000 Electric Shaver
Health & Beauty Logo
23 people viewed this question
Top Razor Health & Beauty Experts
Tom Chichester
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
