Cleaned the metals sensors on the drip tray and in the back of the coffee machine, I have switched it off, unplugged it and left it off for about 15 Minutes but still nothing. All this happened after I cleaned the coffee machine. PLEASE I NEED HELP
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Try using CLR (calcium, line, rust [remover]) or an equivalent product, that is soaked into a Q-tip to clean the sensor. You may need to repeat the process a few times, using a Q-tip with water between to take off layers. Another tip that you may want to do is using a cleaning solution in water to run through the system once or twice followed by brewing with WATER ONLY to rinse it. Hopefully that will solve the issue and leave your unit healthy for a lot more time.
I have an E6 model had the drip tray empty error NOT clearing after cleaning the metal tabs on the drip tray. I believe to found the fault as the tray is often pulled in and out many times a week and causes the connector to become out of alignment and lift up out of position. My fix was find a torch and flat head screw driver and place the machine empty on it back. find the inner connector and push down firmly with your flat head screw driver and you will hear it click into a position, do this on booth connectors and see if it works. please give me a tip if you have been successful , ethereum 0x04160574e307281809016c0c75c26340d5ae3d59
