SOURCE: Lost Safe Keys
The safe comes with 3 keys...2 User keys and 1 master. The user keys require a code and a key to open the safe. The master does't require a code to open the safe. As far as I know, there is no way to open the safe without one of the keys...call for a locksmith...
SOURCE: lost car keys, how to replace ignition/door locks
Can u open the doors using the ignigtion key or is it two seperate keys?
SOURCE: need to take lock cylinder out
You must unscrew the top yoke from the front system and turn it upside down to unscrew the bolts that holds the lock on the yoke.Perhaps the bolts need a hammer and something pointy (with sharp end) cause usually they are headless and you cannot use any tool.After that you should take it to the locksmith and you should not try to disassemble the lock itself.It is very sensitive and you can easily damage it or loose something from it.
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
