SOURCE: Dryer won't stop running - Second try
The push-to-start switch is the easiest and cheapest to replace. You can check it by starting the machine then, unplug it, remove one of the wires from the switch, then plug dryer back up. Dryer should not start. If your model has an even heat board and two relays under the console, your problem could be with them if switch is not bad. Reply back if you need to know how to check them.
SOURCE: Whirlpool Calypso - Will not start
We just experienced the same problem with the buttons! I just kept pushing all the buttons until it switched over-delicate cycle was actually the one that got it going-what a piece of work this machine is!
SOURCE: LG dishwasher shuts off, power failure
Did your problems get resolved? I would love to hear what you found. OK?
SOURCE: will not start. control stuck on glasses cycle. display states "39" cannot change cycle or cancel
Go to the fuse pannel and trip the fuse breaker off and then put it on again. It will reset the automatic cycle. Vitally
SOURCE: timer get stuck on normal cycle
I have had the same problem with my dishwasher 'soultion' make----- not knowing your type if you can try this - simply at the nob (if it has one) spray into it WD40 with nozzel, leave and repeat, this dose not harm elec.parts only improves the connection or dissolves any dirt that made be built up and forming the problem.-if button control place nozzel by grap @ button and follow through.
P
