First look thru your apps. It may already be there. If not, look for your downloader and download Netflix. Please go to your YouTube app and type in your question. It will show you instructions.
Install the Netflix app
http://www.satechhelp.co.za/25121/Netflix-sinotec-smart-tv
visit this site too.
http://electrohelponline.blogspot.com/
SOURCE: netflix problems
maybe this can help. If not, please supply your TV model.
You need to register with Netflix online first to create a login and password.
Here`s how to:
>> On your computer go to netflix.com then click signup or signup.netflix.com
>> Fill all the necessary information they needed.
>> Purchase any plan they offer after you created an account(Optional as you can avail a trial version for 7 days)
Now go to your TV
>> Turn the TV on then hit menu
>> Go to My apps menu
>> Select Netflix
>> Sign in with your username and password
>> Take note of the code
>> Go to your computer and login to netflix.com/activate and type in the code to activate.
>> Go back to the TV select finish to start the service
Important:
Make sure your TV is connected to the internet, either wired or wireless
Here are the three methods to connect wireless on your TV:
Scan and connect
>> Turn on the TV
>> Go to Menu
>> Go to Network settings
>> Select easy then scan for networks
>> Select and connect
Connect using WPS
Press the WPS button(Padlock with signal wave) on your TV`s side panel then on your router.
Note:
You only have two minutes before the router turn the WPS off
Add network manually
>> Go to Menu
>> Select manually add network
Type and select the appropriate settings:
SSID: Name or the Wireless network
Security: Either the WEP, WPA, WPA2 or WPA+WPA2
Passphrase/Passkey: Type in the password
Wait for a prompt that the TV is connected to the internet.
Make sure that your "smart tv" is properly hooked up to your wi fi network. If properly connected and tv is working with other sites then contact Netflix directly and ask for their assistance with their application that is for what ever the reason just not working.
SOURCE: Please email me tv manual of this tv sinotec smart tv 43 LED STL - 43E 390M full he 1080
Your email ID?
SOURCE: Sinotec smart tv no sound remote stuck on 0
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
http://electro-medical.blogspot.com/
not sure if this will help you out,,,
Here's how to fix many Netflix streaming problems. Restart your iPhone, Smart TV, Game Console or whatever device you are using to stream Netflix. Restart your Router. Unplug your wireless router from power for 60 seconds then plug it back in.15 Oct 2015
14 Common Netflix Problems & Fixes - Gotta Be Mobile
https://www.gottabemobile.com/common-netflix-problems-fixes/..
or go to this link...
Netflix wont play Google Search
I have a 50inch sinotec smart TV I have Netflix on activated already and was playing but at times it doesn't work just showing... We're having trouble playing this title now. Please try again later or select a different title.. It's being 2 weeks that iam struggling with Netflix its connect to the wifi but doesn't play at all please help
Error code tvq-pb-101(5.2.102)
Error code tvq-pb-101 (5.2.102) please help
I have a 50inch sinotec smart TV I have Netflix on activated already and was playing but at times it doesn't work just showing... We're having trouble playing this title now. Please try again later or select a different title.. It's being 2 weeks that iam struggling with Netflix its connect to the wifi but doesn't play at all please help error code tvq-pb-101 (5.2.102)
