Krta hun to aavaaj aati hain
I asked google translated that,, and it fails ,why?
what language is that, welcome to the ENGLISH only forum..
tell us what works and does not;
both
this PC is now 13 years old, that be super old
in fact if I saw one run ok that old i'd be GOBSMACKED !
the sound chip on board, can play may files of audio
vast, and for sure with VLC App loaded, vast.
do windows sounds work? in control panel sounds.
does the sound chip in Device manager look ok./?
what OS you run. windows what. XP is now dead. not XP right?
this PC sold here in USA< had XP
XP has 700 + expoits. and is a virus magnet.
and XP has no support, zero
zero on HP
zero at MS.
zero. why in the world run XP, ? time to upgrade it, for sure, if true.
if the sound is 100% dead, all ways,
the look in DM , device manager.
see red or yellow marks on sound chip then the driver is missing.
or unknown, marked chips there. same.
in both cases, all cases, get the driver,
but MS or HP will help after 13 years, 17 for MS.
XP was released in 2001, and is DEAD NOW.
but we can find driver the hard way,but you need to tell
me what sound ship is there, using DM details.
VEN code
DEV code.
then drivers happen.
SOURCE: Compaq Presario V5000
Cant get my screen to read. it is black/blank. Is there a reset button? Compaq pesario v5000 lap top
Chris
SOURCE: compaq presario C754TU sound driver
Go into your device manager in the control panel. Look and see if the driver is installed. If it not installed the sound driver will be in a question mark or exclamation mark status. you can click on propertieas and check the working properties also. Even if everything seems to be working properly as per the settings and driver, you might need to uninstall the driver and put it back in.
Go to the HP website (here) and look for your your drivers. you will find everything for your system here. Follow the directions for installing the driver. This should correct your problem. You driver might have gotten corrupt.
If this corrected your problem rate it as a FIX. If not let us no what you have tried so we can keep helping.
SOURCE: my i-mate mobile phone is dead condition
Vinod Agarwal, aapne farmaya ki full charge battery par hi chalta hai aap ka phone. agar aisa hai to new battery kaistemaal karo. Agar phir bhe dead hai to kriya karm kar do choonki aap ka phone saal bhar band raha aur ab aap us ko daurane ki koshish mein lage ho. Itne waqt me to aadmi bhi mar jaata. kripya battery badlo to shayad chal jaaye.
Hi RAHUL KUMAR, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
