The NHS-B has a semi-sealed tank that keeps +1 pot of water heated and ready to brew. Pouring in a full pot of cold water will fill the top tray and allow a slow trickle of cold water into the top which forces hot water to over flow into the brew basket. This continues until all the cold water drains into the heater tank. So the brew is matched volume per volume. UNLESS the thank was empty or not filled prior to brewing. Follow the brewing instructions from Bunn (on line for *FREE* download at Bunn.com)
* If it leaks (from the bottom) only when you pour in water. Then your pouring it too fast and over flowing the fill tray. slowdown, watch the level in the tray. do not fill past the lid.
* If it leaks just sitting (not brewing) then there is a hole in the tank. Call for service.
* If it leaks after filling the tray half way. then the top of the tank has a leak, loose, cracked, or missing gasket. There is quite a few gaskets on the lid. Call for service.
* Final; Leaks are always bad around electrical equip. Best to unplug and call for service to be safe.
Aloha, ukeboy57
P.S. If you did splash too much water then wipe up as much as you can. Leave it out on a towel or paper towels to allow the excess moisture to evaporate. If you dump all the water out of the brewer (and tank) then you will need to pre-fill it with a pot of water PRIOR to plugging in the brewer. Follow the set up instructions in the manual. Let it heat up and try again. If it's still leaking then there is a hole in the tank. Call for service.
SOURCE: empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
SOURCE: GFi breaker blows
There is an electrical problem with the brewer. If you will please get the model and date code located on the bottom of the machine, and call customer service, we will be happy to assist you with this. The machine has a 3 year warranty and if the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
SOURCE: Bunn coffee maker triggers GFI
Usually this happens when there is an electrical problem with the brewer. If you will call 800-352-2866 with the model and code date from your brewer, we will be happy to assist you with this issue.
SOURCE: Tim Horton's home brewer Bunn coffee maker
My Tim Hortons coffee pot leake water out the sides when I add water to make more coffee. What should I do ? I like the coffee maker it makes great coffee,
