Network is BT home hub 6
You should be able to fully use your Amazon Firestick, and if you have Amazon Prime, be able to access all prime and free offerings from Amazon.
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
SOURCE: comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me.
Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
