Question about Bunn Coffee Makers & Espresso Machines
I just bought the Bunn VLPF series, double burner. My other Bunn coffee pot had the option of make a half pot of coffee but this one does not Is there a tip to follow for half a pot?
    Master:
  • Bunn Master
  • 791 Answers
Sorry this brewer is usually set up for a full pot brew. I have reset this for a small (but not half) pot brew as the customer wanted to use a metal carafe (with their own logo). I also tried once to get it to half pot brew but it can get tricky if you actually brew twice to get a full pot (in the same pot).
* there is a siphon action that starts once the boiler tank gets filled to a certain point. From that point it will continue to flow until the boiler is emptied to the level that stops the siphon action and leaves enough water in boiler to reheat for the next brew. Achieving the siphon point may be a larger volume of water for 1/2 a pot but may work for 3/4ths a pot. The 1/2 way mark may be affected by the brewers "level" while placed on a table or sagging in the middle of a weak table.
* Usually if you want a smaller brew then go with a smaller brewer. Though there is a hot water tap that will give you 2-4 cups of hot water (it gets tepid after that) which you can use for the "Mug" style brew. But it does get messy.ukeboy57
* Final, If you don't mind a little more than 1/2 pot brews then ask your vendor to adjust the machine for you. Though a reminder NOT the double brew in the same pot as it will overflow.
Aloha, ukeboy57
Posted on Jan 19, 2018
SOURCE:
  • 60 Answers
SOURCE: Bunn VPS 3
Are you leaving the machine plugged in all of the time? If not, you need to. The machine takes approximately 10 minutes to get to full temperature the first time then the water should stay hot from then on. Or it could be that you just need to turn up the thermostat. No, the water won't get hotter sitting on the burner and the coffee won't taste as good if the water you are brewing with isn't hot enough.
To get to the thermostat, unplug the machine and take the two screws on the top lid off. You should see a box that has a knob or a T sticking out of it. Turn it up a little bit, put the lid back on and let the heat up for a little while (10 - 15 minutes). Try brewing with just plain water. If it still isn't hot enough, repeat the steps above. Make sure you don't turn up the thermostat so much that the water boils.
Posted on Nov 06, 2008
  • 131 Answers
SOURCE: Water over filling pot
There is a brew timer on the left side of your machine near the heater switch. you need to remove an access panel to access it. turn this down a little, let the water heat up, then try another brew. Adjust as needed, brewing another pot between each setting.
Posted on Feb 13, 2009
  • 508 Answers
SOURCE: bunn automatic coffee maker will only make half a
try cleaning with white vinegar(50/50 with water)may have calcium deposits supposed to clean once a month-let it soak overnight use coofee filter to catch deposits run numerous times then throughly rinse with water!!! :)
Posted on Jul 04, 2009
  • 189 Answers
SOURCE: my Bunn coffee pot leaks water theres always a
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Posted on May 19, 2010
  • 35 Answers
SOURCE: Bunn VPR Series Coffee Maker
This machine has a reservoir that holds about 2.5 pots and keeps them at brewing temperature. Therefore you should pour in 3 pots (with a pot in place under the filter basket) until water flows from the basket. Then, and ONLY then, it is safe to plug in the brewer. If you plug in the brewer BEFORE filling the reservoir you will burn up the heating element and will have to have it replaced.
After the initial filling and heat up (about 20 minutes) you are ready to pour through a pot of COLD water through and brew.
Posted on Sep 10, 2010
WE HAVE A BUNN VLPF SERIES COFFEE MAKER. WHEN YOU PUSH THE BUTTON TO MAKE A POT OF COFFEE, THE WATER DOESNT STOP AT ONE POT IT MAKES 6-7 BEFORE IT STOPS. IF YOU TURN OFF THE MACHINE WHEN THE DECANTER IS...
Sounds like your timer part #32400.0002.This is the new type timer which replaces the dial timer.Another thing is does this happen when you turn on the on/off switch? I would also check your liquid level probe in top of tank.Always a possibility bad liquid level board.If it only does this when you push the brew button the timer is bad.
Feb 07, 2011 | Bunn VLPF Coffee Maker
My bunn vlpf coffee maker the water tank is overheating to the point of steam is spewing fro the air release tube... I'm thinking thermostat ?
You are correct.Also check the tank for lime.By unplugging and removing top of machine (2) screws and remove fill basin.You can then remove your t-stat probe to check.If it is lime up you can crack off the lime and reinstall it in the tank.If limed up I would suggest de-liming.T-stat part# 4314.0001.
Jan 29, 2011 | Bunn VLPF Coffee Maker
The water comes out warm from both the coffee maker and the hot water tap. I have the BUNN VLPF series. This machine is only 4 months old and has never worked correctly.
Is it still under warranty? Bunn should take care of it for you if it is. Usually if the coffee is only warm it may mean that a thermal limit has tripped. The water stays warm because the tank has a heater blanket that is wrapped around it but you aren't getting any power to the heater that is in the tank.
mike@espressomachineexperts.com
Nov 02, 2010 | Bunn -O-Matic Corp. 2 Warmer Auto Brewer...
How do i clean my bunn air pot coffee brewer?
Run a pot of half water and half vinegar through the coffee pot and you may need to repeat this process a couple times to get all the calcium buildup cleaned out of the pot. Hope this helps.
Jun 21, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Our office has a VPS series coffee maker. We pour pre-measured water into the reservoir to make coffee. The coffee maker makes only one-half pot. The next time we make coffee, the pot overflows. This...
The machine is always on, so it is never full the first time you use it on monday. Try this before you use it on monday pour in a full pot of water in the brewer and put an empty pot under the head. Wait about 7 minutes, the machine will fill the tank and then be ready for brewing coffee.
Jan 21, 2010 | Bunn VPS Coffee Maker
Bunn automatic coffee maker will only make half a pot, this is a commercial unit with 3 burners
Jul 04, 2009 | Bunn NHB Coffee Maker
The procedure for setup of this coffee maker can be found here -
http://www.bunn.com/pdfs/commercial/manuals/10613.0000.pdf
Please email if you have additional questions.
Feb 02, 2009 | Bunn Automatic Coffee Brewer CWTF15 1
Jan 07, 2009 | Bunn-O-Matic Coffee Brewer GRW8
Overfilling
There is a timer located in the top of the machine. Take off the two screw and turn the timer down a little bit.
Jan 24, 2008 | Bunn VLPF Coffee Maker
Coffee Makers & Espresso Machines Logo
184 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
