SOURCE: right earbud plays really soft.
Here is a tip for people attempting to fix the mesh (which, as it happens, works great when done carefully)
use a set of nail clippers or small tweezers to grab the edge of the mesh and pull the mesh away from the earbuds. If you disconnect it completely, do not get upset. Use the tweezers to carefully scrape both sides of the mesh (try not to be surprised at the gunk that comes off)
Once you scrape them clean, carefully try to re-attach the mesh. if you pulled it off entirely and cant get it back on, you may have to be careful about your earwax buildup on the unit, as it can get deeper inside the earbud now that the mesh isnt protecting the interior. Otherwise, pop the bud's cover back on and enjoy your music!
Ive done this fix on two sets of earbuds since discovering it. One set had what I thought was a non-functional right earbud, but it turned out that the mesh was blocked and interfering with the sound! It was working like new moments later and I was very happy to not have to purchase new ones.
SOURCE: When I put my earbuds into my ipod touch only one side works
You need to get the headphone jack replaced from apple.
SOURCE: My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
SOURCE: The right earpiece doesnt work
Sooo... how many times will it take for you to switch to another kind or earpiece? Sorry...Door waas wide open for that one.
i have the same problem. its not the headphones. its the itouch. its something to do with the jack-i think. because whenever i jiggle the plug eventually i can hear some of my music eventually. its a pain. and so how do i fix that ish?
I have the same problem. Can't seem to get both to play at the same time.
ANYONE KNOW WHAT TO DO?
let them cool off before you charge them. Did you try reconnecting them to use together? Hmm it seems the manual says to pres twice some say you need to tap the button 3 times to get the flashing lights to turn all blue in unison.
