Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Dear Sir,
When you pressed sleep button TV goes to standby mode.It means it goes to power saving mode.Advantage of this feature is you can set the sleep timer,so tv on that particular time it goes to standby or power saving mode.It is helpful when you are watching tv on bed if you want to sleep no need switch off TV plugs,just press sleep button from your place only, TV goes to standby mode.
It is the actual meaning
I think it cleared your doubt
good luck
chandrashekhar
Welcome back to Fixya Customer Support
thanks for your comment
Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
Step 2
Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
Step 3
Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
Step 4
Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
Step 5
Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
Step 6
Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
1 Press the ON/STAND-BY button to turn the power on.
2 Press and hold the CLOCK/TIMER button.
3 Within 10 seconds, press the or button
to select "ONCE" or "DAILY", and press the MEMORY
button. Set the clock to the correct time if "ONCE" or
"DAILY" does not appear.
4 Within 10 seconds, press the or button to select
"ONCE SET" or "DAILY SET", and press the MEMORY
button.
5 To adjust the hour, press the or button and then
press the MEMORY button.
6 To adjust the minutes, press the or button and
then press the MEMORY button.
7 Set the time to fi nish as in steps 5 and 6 above.
8 To select the timer playback source (CD, TUNER, USB,
iPhone/iPod, TAPE or AUDIO IN), press the or
button. Press the MEMORY button.
When you select the tuner, select a station by pressing
the or button, and then press the MEMORY
button. If a station has not been programmed, "NO
PRESET" will be displayed and timer setting will be
canceled.
9 Adjust the volume using the VOLUME control, and then
press the MEMORY button. Do not turn the volume up
too high.
10 Press the ON/STAND-BY button to enter the power
stand-by mode. The "TIMER" indicator lights up and
the unit is ready for timer playback.
11 When the preset time is reached, playback will start.
The volume will increase gradually until it reaches the
preset volume. The "?" or "DAILY" indicator will blink
during timer playback.
12 When the timer end time is reached, the system will
enter the power stand-by mode automatically.
Once timer:
The timer will be canceled.
Daily timer:
The timer operates at the same time every day. It
will continue until the daily timer setting is canceled.
Cancel the daily timer when it is not in use.
The light flashes constantly at a rate of about 50 per min. I'm aware it is in standby mode but how do I get it out of standby. Maybe I didn't provide enough information. Thanks for the responses
