This is a built-in Electrolux Convection Microwave oven. It doesn't heat when in microwave or convection modes.
SOURCE: Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
SOURCE: The interior light on my microwave convection oven doesn't light.
If
there's no obvious removable cover over the bulb (and the owner's
manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
On an over the range type, remove the vent grille across the top and
see if bulbs can be accessed there. There may be a panel on the bottom
covering the light(s), instead.
If not, chances are
you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
SOURCE: electrolux microwave PLMB 209DCA sparks
No solution yet but have ordered a replacement high voltage capacitor. If this works, I'll let you know.
Your expert did not respond to one of my questions which was whether he had experience with this type of problem with a microwave magnetron. When he did not reply after a substantial period, I assumed he had given up on the problem.
SOURCE: GE Microwave/Convection JVM 1090 oven won't reach temperature
You probably have a bad thermistor.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
(At that site, that part is misspelled as "thermister" for your model).
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the left side behind the grille, which is
very
helpful
when troubleshooting & testing.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Accessing some components for testing will require you to remove the oven from the wall.
If
You can download GE
We're
SOURCE: GE microwave replacement magnetron
I also have a HotPoint (GE) Spacesaver Microwave Oven (MWO)that we got at Home Depot about 3 yrs ago. The magnetron quit yesterday and I found out online that this is a common occurance with GE MWO's. I found this string and thought I would attempt to have GE send me a magnetron to replace the defective original part.
I called Customer Relations (1 800-386-1215) and spoke with Nikita. I informed her nicely that I was aware that this is a common problem with GE MWO's and that I am a Union Electrician who would like to perform this repair myself. I simply needed the replacement part. She was very understanding and asked for the model and serial number and after a few minutes she supplied me with an order confirm #.
The part should arrive in a few days via FedEx and we will be back into space age cooking and also our appliances will still match. Thanks to all who posted to this string and clued me in (You have saved me a C note!).
David in Omaha
Hi - From what you have described it sounds like the microwave possibly has a wiring failure or faulty control panel or magnetron. I would suggest contacting a professional that accurately diagnose and repair the unit
