Tomtom GO 930 GPS Receiver Logo
Posted on Jul 30, 2009
TomTom GO 930 remote can't scroll entries in phonebook
After upgrading TomTom GO 930 to 8.351, the remote control can't scroll entries in the phonebook unless I manually touch the next page icon on the the touch screen first.
Any suggestion please ?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
381
Points
I have (had!) the same problem as you and I found this thread:
http://www.tomtomforums.com/tomtom-go-920-920t-930-930t-940-950/19455-remote-control-arrow-buttons-dont-work.html
I downgraded to the 8.302 version and the problem is solved!
Jacques
2answers
My vetch 17550. Cordless phone tells me I have 35 missed calls. How do I delete this message
From the user manual...
View a Call List Entry
1. Press CALLS when the handset is not in
use.
2. Scroll to browse through the Call list.
Dial a Call List Entry
• When the desired entry appears, press
/HOME or to dial.
Save a Call List Entry to the
phonebook
1. When the desired Call list entry displays,
press SELECT.
2. Scroll to To Phonebook then press SELECT.
3. Use the dialing keys to modify the number if
necessary, and then press SELECT.
4. Use the dialing keys to enter the name, and
then press SELECT to save.
Delete a Call List Entry
• When the desired Call list entry displays,
press DELETE.
Delete all Call List Entries
• Press MENU when the handset is not in use.
Scroll to Call log and then press SELECT.
Scroll to Delete all and then press SELECT
twice.
Following url for manual.
https://auphones.vtech.com/home-phones/cordless-phones/302
How do you put numbers into phonebook inan aspera f36.
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes
To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/D1760om.pdf
Aug 15, 2017 • Cell Phones
How do i delete numbers from my BT XENON 1500 phone
Delete an entry in the phonebook
1. Press Names.
2. Scroll to the entry you want.
3. Press Options and scroll to Delete Entry and press OK.
Display shows Delete?
Press Yes to confirm or No to cancel.
4. Press Back to return to the standby screen.
1helpful
How do I delete a name and number on the BTHudson 1500.
Delete an entry
1. Press Nam es. Scroll to the entry you want and
press Select.
2. Press MENU and scroll to Delete entry and press
SELE CT, then OK to confirm.
3. Press Bac k to return to standby.
Delete Phonebook
1. Press Menu. Phonebook is displayed. Press Select.
2. Scroll to Delete all and press select.
3. Delete All? is displayed press OK to confirm or bac k
to cancel.
4. Press Bac k to return to the previous menu.
for full manual please follow the link below :
http://www.shop.bt.com/content/uni2/documentation/693m/bt_hudson_1500_user_guide.pdf
3helpful
2answers
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
16helpful
How do I replace a TomTom go 930 battery
Replacing the TomTom Go 930's battery is actually not all that hard as this video demonstrates:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=TOMTOM+GO+930&Show=ExtInfo I swapped the battery of a friend's dying GPS using the aforementioned kit and all went well. His Go 930 is back up and running smoothly.
Hope this Helps, aaron
1helpful
Cannot scroll phonebook entries in my TomTom GO 930 using the remote control unit. It used to work, but doesn't now. Suddenly just stopped responding to remote controller. Scrolling of other lists (eg....
Apparently tom tom have stopped supporting this feature which is why the remote will not activate the scrolling. Absurd if you as me I have a 307 and it's a damn deep windscreen I used the remote to handle my calls! Now I can't make calls I can do a redial and accept calls.
You can manually scroll using your finger. I think the Dutch have gone crazy. Best thing to do is log this with technical and log it as a complaint!!
1helpful
How to add calling card 800# and PIN to expedite LD calling.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
2helpful
How do u change the time on the TomTom go 930
Tap screen, tap change preferences, right arrow to page 8...
I have a tom tom 930.
get the latest tomtom Home 2.5 application from www.tomtom.com and use this app. to install your new map. you may need to set up a registeration when you visit tomtom, but the map should go on to the device as long as you have room. put everything else i.e. phonebook, music, pictures on to the card.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
