Question about Hitachi 57G500 57" TV
Hitachi 57G500a no picture but has sound
The picture went out on my tv I do have sound. When I opened the back panel there was a red LED next to what I think is the power supply. Any advise would be helpful.
  • dgoofy Nov 25, 2007
    dido that
    Novelist:
    Champion:
  • 244 Answers
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
No picture
Replace IC (TDA8385J)
Sound but no picture
Check the LOT cable for short circuit
Posted on Nov 24, 2007
SOURCE:
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
43FDX15B No picture, Power light stays on
Just a thought, but check all of the pico fuses for a blown fuse. The pico fuses look like a small yellow resistor. Some Hitachi's are famous for having a blown hi-volt ceramic capacitor and a blown pico fuse.
I think the red led on is a short protect indicator, but I could be mistaken.
Sep 08, 2009 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Hitachi 60SBX78B No sound or Video
replace pico fuse E994 and capacitor C707. You have to disconect alot of wires and remove the screws holding the boards. you DON'T have to remove the large high voltage wires. You have to stand the board on it"s edge to unsolder the components from the back side of board. Good luck it worked fine for me. fcs0998@aol.com gene
Apr 27, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Picture is blurry
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
Jan 28, 2009 | Hitachi 51F500 51" Rear Projection...
DP23 LED not lit on deflection board no picture on tv
Good Day, Gil;
Your problem is in deflection circuit (115+v) check these: FP05, DP15, Q777, QH01, TH01, T701, etc. BUT suspect C707 1k pfd, 2kv, and check all the pico fuses (brown) 2" to the right of cap. Good Luck, big IRISH.
Jul 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53udx10b
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Jan 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 57G500 57" TV Logo
377 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
