Washing Machines Logo
Nicholas Gigis Posted on Dec 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a new Maytag mvwc565fw. The Clean Washer Cycle was interrupted from a power outage and the unit is full of water and the lid is locked (light solidly illuminated). Trying to start any other cycle does nothing. Unplugging does not reset it. I couldn’t even get the diagnostic mode come on.
L Vincent Testa
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Maytag Master 724 Answers
  • Posted on Dec 27, 2017
L Vincent Testa
Maytag Master
Level 3:
Renaissance:
Answers
724
Questions
0
Helped
367445
Points
3088
Resolution:If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
  • Nicholas Gigis Dec 27, 2017
    No change. Still full of water and lid locked.
5 Related Answers
Anonymous
  • 619 Answers
  • Posted on Jan 09, 2008
SOURCE: Maytag washer not reset after power outage
The magnetic switch was stuck due to power outage / contactor are spark connect the contactor stuck together .Magnetic switch to replace.
A
Anonymous
  • Posted on Aug 18, 2008
SOURCE: washer won't run through a complete cycle-stops at 29 minutes
There is a service manual behind the control panel it will show you how to test the door locks. If might have a bad lock solenoid.
Phoebe112
  • 9 Answers
  • Posted on Feb 14, 2009
SOURCE: Kenmore Elite 10.4708 front load washer won't start with new load
Uh oh! It did it again! This time I had to unplug 6 times for one cycle. Seems to be on the last 2 minutes most of the time. Today my husband is taking the control unit and looking for soldering problems. On Askmehelpdesk.com this man told of taking the bottom panel off and there is a little black latch thingy you pull to open the door lock manually. Also he said that the K2 and K4 relays are usually the problem if it isn't a soldering issue on the connectors. ( On the CCU);. He said one of them is usually burned and to clean it off and then switch it with the other one which carries less voltage, therefore doesn't burn. You can use a pencil eraser to do this. My husband told me they did this in the Army for MOose code contacts. He just told lme the soldeirng looks good on the connectors and is now working on the K2 and K4 relays. If you go to Askmehelpdesk.com/appliances you will see these tips are for the Whirlpool Duet whic is apparently the same machine as our Sears Kenmore H4's. Gosh, I hope this helps someone as it sure is not fun trying to track this problem down. I am glad you got Sears to come out. I will NEVER and I repeat NEVER buy from Sears again! Did I mention I wrote a letter months ago when I was having a hard time getting warranty work done.( Which I never did) that I had written to the pPesident, CFO and the Texas Attorney General for Consulmer Protection Division and never got a response from anyone?
Anonymous
  • 51 Answers
  • Posted on Jun 14, 2009
SOURCE: Stops drains and bleeps with only spin light illuminated
It sounds like you need to re programme the
machine.
With the machine plugged into the wall and
turned on and the headset turned off this is what
you do.
Push and hold down the start button, while doing that you need to then push and hold down the power button.
Hold them down for about 5 seconds, during
which time you may a series of up to 3 beeps.
Then release the buttons.
Turn the machine off and then on again followed by the start button. Allow the machine to then run the complete cycle.
This should correct your problem, if this doesn't then you may need to then look at replacing the computer panels.
Anonymous
  • 6 Answers
  • Posted on Jun 22, 2009
SOURCE: I have a Whrilpool model LHW0050PQ4. Lights are blinking nonstop.
you need to turn off, unplug, plug back in, turn on, move cycle knob to stop, wait a few minutes, and then select cycle you desire, press start and hold handle firm against door 'till light stops blinking and it should go.
Why is my Maytag washermodel mvwc416fw stuck on sensing?
Turn off the deep clean and extra rinse cycle options.
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
My Maytag Neptune washer stopped in mid cycle because of a power outage. Now it will not complete a full cycle. When I open the door, there is a pool of water in the tank. I have unplugged it, started it...
Try spin only cycle. Should drain water then spin. If that doesn't work it may be the power outage started as a power spike and fried your control board. Good luck.
Maytag Atlantis MAV6250AWW won't rinse or spin?
clean motor rollers(belt may be slipping)
9vopy...paste)
Washer will not fill with water
Check the lid switch...this controls all power to the machine and if the lid isn't closed, it can interrupt the water fill even with the lid appearing to be closed. Press firmly on the center of the lid when it's closed. Sometimes the lids on these maytags get tweaked a little and then don't allow full contact with the switch... Let me know ..
KEN
1helpful
Kenmore stacked washer / dryer 2002
hi thanks for the question so your saying your tub is full of water ,did it stop in the middle of the wash cycle or at the end of the wash if its at the end of wash and it doesn, drain then you have a lid switch problem . if thats the case reset your timer as if you want to start a new wash load if it starts to wash your timer is ok replace the lid switch
Washer will not restart.
unplug it wait a few mins---- that should solve it sometimes these machines go in to a a "soft lock" condition
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
