SOURCE: We have a Franke Evolution
E43 error motortime out refers to the brew unit not being "sensed" by the micro switch, the most common fault is the micro switch failing. other causes are the failure of the brewmotor itself, or bushes within the brewer. The micro switch is simple to replace as its obvious withits location. the other however will require the expertise of an engineer.
SOURCE: not a problem more of
the evolution is a super automatic ,im not sure what you mean by water processed? but i do know you need water with a low ppm of hardness or you risk ruining the machine. water processed refers to the way beans are prepared, usually decaf.
SOURCE: I have a Franke Evolution
Fault Code 3 is a water fill problem. If interested I can lead you to the problem
