Question about Welding Tools
Pro Cut 25. Plug power in and power on, seems fine. Plug air hose on and safety light comes on immediately and will not function at all. Any ideas?
  • 901 Answers
Page 25 of this says that the 'consumables are not properly installed.' If they are properly installed cycling the power will allow you to resume.
Lincoln Electric IM665 PRO CUT 25 Manual Page 25
Posted on Jan 02, 2018
4 Suggested Answers
SOURCE:
  • 13 Answers
SOURCE: safety light flases on a lincoln pro-cut 80 and mashine wont work
sounds like the torch tip is not tight.with a hypertherm you have to turn of the machine to reset .
Posted on Jan 06, 2009
  • 73 Answers
SOURCE: pro cut 25 plasma cutter : turn it on and get a
yes you need to find and fix the leak, it will show fault if not enough air pressure is there, double check airline connection exterior, and then airline interior after regulator valve also check for are around the regulator,
hope this helps.
Posted on Feb 03, 2010
Testimonial: "thank you very much this is a very big help for me have a great night jon"
  • 38 Answers
SOURCE: The safety light on the Pro cut 55 will not stop
alot of times the torch can be clogged up and that will make it come on
Posted on Apr 23, 2010
I need a validation code fro quickbooks pro 2011. the Licen number1063-0575-1585-222. and Product number 019-147
i have a dell latitude E5520 laptop,having a power-cut issues,the moment you press the power button,the light comes on then goes off immediately,. when u plug in the charger,the charger light indicator turns on and also goes off immediately. i need help to solve it.
Thank you
Aug 01, 2017 | The Computers & Internet
Hi Just wondering if you could tell me some troubleshooting ideas for an Amana air conditioner--it seems to be getting power--we are hearing a noise coming from the unit indicating that it is getting...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
To start a compressor you need a start contactor - relay and a capacitor. The click you hear could be from the contactor, which could be normal OR could mean that the contacts are not staying closed which would not allow the compressor to start.
Jul 22, 2011 | Amana Heating & Cooling
Shuts on on safety ,,almost immediatley
Check that the tip is assembled correctly.If is not in properly, it will not arc. Second, check air pressure switch. Sometimes they become stuck from corrosion due to moisture in the air. Test the operation with a tester
Nov 01, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
Hello, Engine not firing,turning over fine(lots kick) NO fuel getting to fuel rail.i have taken the hose off (fuel line to fuel rail)and turn ignition on and NO fuel coming out. Engine light is...
is your fuel pump on check for a safety cut off switch to see if it needs to be reset. if not a power to pump problem could be your pump sock is plugged or the pump has failed.
Oct 01, 2010 | 1999 Toyota 4Runner
Start cutting and the safety light comes on
Usually it could be one of two things. The first thing to check for is to look at the contact and make sure it is not melted down and ensure its in good shape. The second thing that could do this, would be not enough air pressure. This air pressure is used to blow away the molten metal you are cutting.
May 29, 2010 | Lincoln Electric Plasma Cutter, Pro - Cut...
Problems with Lincoln LINCOLN ELECTRIC K1756-1 PRO-CUT 25 PLASMA: all settings ok, air ok will spark on occassion and then nothing. tried everything put will only lit very seldom and then nothing.????...
Try using fine sand paper and clean the tip of electrode and the thing that looks like thimble, another solution was don't tighten tip cover too much back off a little til you ge good contact. some units don't like to be clicked ON without making contact with working metal, you may get two or three clicks and then nothing til the air stops flowing.
Feb 03, 2010 | Lincoln ELECTRIC K1756-1 PRO-CUT 25 PLASMA...
Pro cut 25 plasma cutter : turn it on and get a fault and hear air leaking from some place. will not cut just a safety fault
hope this helps.
Feb 03, 2010 | Lincoln Welding Tools
When air is hooked up it blows the air regulator and all the air blows out valve very little gets to gun.red safety light comes on on front of machine and it will not work
Air pressure should be no more than 90#s. If regulator cannot handle at least 125#s . Get a new regulater. Sounds like this regulator has a blown diaphram.
Nov 11, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
Safety light
check the gun lead all the way back to unit,if there is a nic or cut in that lead (main power lead)the unit will not fire,sadly you cannot fix the lead ,it has to be replace with new one,
Jun 06, 2009 | Lincoln Electric Plasma Cutter, Pro - Cut...
91 miata mx-5 cuts out at 2200 rpms- cant smog- check eng. lite isn't on
The very first thing to do is replace the ignition wires. These were a very common problem on Miatas. Since you're taking them off, it would be a good idea to change the plugs as well. These things are really just maintenance, but one other thing to check is the condition of the intake hose. It is critical that the hose that runs between the throttle body and the airflow meter has no cracks or flaws. Sometimes they are hard to see because the hose has creases in it. It's a good idea to take the hose off and inspect it carefully. If it is broken in anyway, the airflow meter won't know how much air is entering the engine and fuel will be cut off.
Apr 05, 2009 | 1991 Mazda MX-5
Welding Tools Logo
188 people viewed this question
Top Welding Tools Experts
David Soto
David Soto
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
