1996 Chevrolet Caprice Classic Logo
Hardwick Cory Posted on Dec 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 96 caprice classic vats security system has y car shut down. I had a after market ATS security chip also in my car and I removed it thinkingvthat was the problem. It wasnt.
The security light was still on. I bypassed it and it started and worked for about 3 days. Then I drove it to get a new tire and try to start it at the tire shop and security light was flashing. It turns over but but fuel pump shuts down after a couple seconds. I was told to get a VATS bypass module so I did and now Im stuck. No instructions on what to do with it. It has five wires coming out of it. I dont know what to connect it to.I bought 2 new keys one chipped one not. Still wont start. Security light stopped flashing but still on.
Kevin Campbell
Level 2:
Sergeant:
  • Chevrolet Expert 227 Answers
  • Posted on Dec 29, 2017
Kevin Campbell
Chevrolet Expert
Level 2:
Sergeant:
Answers
227
Questions
Helped
82400
Points
529
OK. Turn on the key, let the light start flashing. Leave the key in the ON position. Leave it that way for 10 minutes. The VATS security is supposed to discourage a thief from stealing your car. It will flash for 10 minutes and then it will stop flashing. Now,,,,,, DO NOT turn off the key. DO NOT turn it off. Simply take ahold of the key and crank the car up. It will start and should never happen again, unless someone removes the instrument cluster, the battery, or other vital items like the ECM PCU. Good luck.
1 Related Answer
LARRY
  • 25 Answers
  • Posted on May 29, 2009
SOURCE: 1985 corvette vats system w/o chip in key need to bypass
REMOVE THE INFO PANEL IN THE CENTER. THE RELAY IS BEHIND THE INFO PANNEL. YOU CAN HEAR THE RELAYS CLICKING. YOU CAN CUT THE WIRE OF THE RELAY TO STOP THE RELAY FROM ACTIVATING THE IGNITION CUT OFF.
IF NO OIL PRESSURE THE ENGINE WILL STOP, CHECK THE OIL PRESSURE. GO TO CORVETTTE FORUM .. NEED SLEEP !
1helpful
2answers
I want to delete or completely remove the whole vats security system from my 96 Riviera
Here is a better video by a professional tech. GM VATS Key / Resistor Key Security Bypass - YouTube
But if you want to completely get rid of it you need to have a remanufactured ECM/PCM with it removed . Call an talk to these folks at flagship one. Engine Control Module ' Powertrain Control Module ' Auto Computer (fs1inc.com) cost you around $300 to $400 bucks
My 96 chevy caprice security fault light is on and car turns over starts but does not stay running. The fuel pump seems like its being shut down. How can I fix this problem?
The fuel pump isn't being shut down , the engine computer isn't seeing a anti-theft system pass word (code) so it disables the fuel injectors . The security light on ? DTC'S - diagnostic trouble code's are stored . Need a factory or professional scanner to read this code's . You could try a by pass of the key an lock cylinder ,but that may not be the problem . Does your key have a resistor pellet on the side of the key >
GM VATS Key Resistor Key Security Bypass
1helpful
My oldsmobil achieva 96 stop runing on me some times will start i put starting ful in it then it will start what do i do about of could be
It's that infamous "chip" in the key that becomes a nightmare to many. The security light may or may not start flashing. Sometimes it stays on steady. Gradually the car begins not cranking anymore or if it cranks it will start and die in a second. Randomly it will do this more and more often until it won't start anymore. VATS, PASSkey and Passlock immobilizer systems are killing cars all over North America, they have a short lifespan and are certainly more effective against owners than thieves. Here is how you save your car
QUICK FIX TRICKS
1st trick, Try a spare key that is newer or used less. The pins wear down with use and so do the keys causing the security to fail.
2nd trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year. If its shutting down while running, I'm sorry I have no quick fix...
CHEAP FIX: Bypass the chip in your key. This is temporary, but effective until the TDM (theft deterrent module) in the dash poops out. Then you're kinda screwed. I was told that these types of key security systems have a 7-10 year life span. Sucks for us. This link explains the "Key Issue" pretty well.
----- http://vats.likeabigdog.com/
If you're gonna tear your car apart anyway, just do this next fix and bypass it all together. Its more money, less work, and a PERMANENT fix. Up to you tho.
NEVER WORRY AGAIN FIX: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. It took longer to find the solution than it did to fix the problem. They sell a unit for 200 bucks to totally bypass this system FOREVER. life time-money back and all that. Finally did this in my car. Well worth the 200 if you've looked into getting this replaced... It can cost anywhere from 600-1000 bucks. If you do buy this, please purchase it thru this link.
----- http://newrockies.ca?ap_id=judd0081 ----- With this fix, you can take that whole Vats, passlock, passkey system out of your car all together. Good info on both sites.
It works for:
Any GM or Isuzu Vehicle with VATS or PASSKey or PASSLock security systems.
If your car has the chip in the key or in the lock cylinder, then you can save it with this Full Bypass.
It works for, but is not limited to:
Trucks
GMC/Chevy
1998-2006 S10/T10/Sonoma
/Blazer/Jimmy
1998-2007 Suburban/Avalanche
/Tahoe/Yukon
1998-2006 Sierra/Silverado
2002-2008 Trailblazer
2003-2006 SSR
1998-2006 C1500/C2500/C3500
1998-2006 K1500/K2500/K3500
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1994-2003 Grand Prix
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1994-1998 Trans Sports
1988-1999 Bonneville
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-1996 Century
1993-1996 Regal
1982-1999 LeSabre
1991-1996 Park Avenue / Ultra
1994-1996 Roadmaster
1991-1996 Roadmaster Estate Wagon
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
1982-1990 Electra (all models)
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1994-1999 Eighty-Eight
1991-1996 Nighty-Eight
1998-2002 Intrigue
1990-1992 Toronado
1994-1997 Cutlass Supreme
1997-1999 Cutlass
1997-1999 LSS/Regency
1997-1999 Silhouette
1991-1996 Custom Cruiser
Chevrolet/GMC
1998-2005 Astro/Safari
1998-2008 Envoy
2005-2006 Equinox
1998-2007 Savana/Express
1995-2005 Monte Carlo
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-1991 Corvette
1994-1996 Caprice/Caprice Wagon
1995-1996 Impala SS
2000-2005 Impala
1997-2005 Malibu Classic
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1985-1996 Fleetwood Brougham
1992-1995 Seville
1992-1995 SLS/STS
1985-1995 Deville
1994-1995 Deville Concours
1988-1995 ElDorado
1994-1995 ElDorado Touring
1999-2007 Escalade
Saturn
2000 LS/LS1/LS2/LW1/LW2
2001-2002 L100/LW100
2001-2003 L200/LW200
2001-2005 L300/LW300
2004-2005 L-Series
2002-2008 VUE
1996-2002 SL/SL1/SL2
1996-2002 SC1/SC2
1996-2002 SW1/SW2
3helpful
Service light comes on and security light blinks and the car will start then shut off
It's when the security light starts flashing that the infamous "chip" in the key becomes a nightmare to many. Gradually the car begins not cranking anymore or if it cranks it would start and die in a second. Randomly it will do this more and more often until it won't start anymore. VATS, PASSkey and Passlock immobilizer systems are killing cars all over North America, they have a short lifespan and are certainly more effective against owners than thieves. Here is how you save your car
1st trick, Try a spare key that is newer or used less. The pins wear down and so do the keys causing security fail. 2nd trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year. If its shutting down while running, im sorry i have no quick fix... If anything on this page helps you, please remember to comment or give me a thumbs up on the myfixya sight so i can have a better rating to help more people on this. Thanks
Cheap fix: Bypass the chip in your key. Temporary, but effective. Until the TDM (theft deterrent module) in the dash poops out, then you're kinda screwed. I was told that these types of key security systems have a 7-10 year life span. Sucks for us. This link explains the "Key Issue" pretty well.
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. They sell a unit for 200 bucks to totally bypass this system FOREVER. life time-money back and all that. Finally did this in my car. Well worth the 200 if you've looked into getting this replaced... Anywhere from 600-1000 bucks. If you do buy this, please purchase it thru this link. The cost is the same, but i get credit for the sale and im trying to earn my money back, as you will be able to do if you buy fron NewRockies and join the free affiliate program. Thanks
It works for:
Trucks
GMC/Chevy
/Blazer/Jimmy
/Tahoe/Yukon
2003-2006 SSR
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-2005 Century
1993-2004 Regal
1982-1999 LeSabre
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1998-2002 Intrigue
1990-1992 Toronado
1997-1999 Cutlass
Chevrolet/GMC
1998-2008 Envoy
2005-2006 Equinox
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-2004 Corvette
1995-1996 Impala SS
2000-2005 Impala
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1992-2004 Seville
1992-2004 SLS/STS
1985-1999 Deville
1994-1999 Deville Concours
1997-1999 Deville D'Elegance
1988-2002 ElDorado
1994-2002 ElDorado Touring
1999-2007 Escalade
Saturn
2004-2005 L-Series
2002-2008 VUE
1996-2002 SC1/SC2
1996-2002 SW1/SW2
Ok what going on when my car shut off at a complete stop
1st trick, (if not starting) turn the key forward 2 clicks till right before it would normally start, leave like that for 10 minutes. ( no less ) After 10 minutes, turn key back then forward and your car might start. I did this in my regal for more than a year. If its shuting down while running, im sorry i have no quick fix...
Never worry again fix: Bypass the whole VATS/Passlock/passkey I or passkey II system entirely. Literally take it out, and throw it away. I just did this in my Regal. Took about an hour. Took longer to find the thing than it did to fix the problem. For a list of cars effected by this problem. See the NEWROCKIES link on the right side of their page......... They sell a unit for 200 bucks to totally bypass this system FOREVER. life time-money back and all that. Finally did this in my car. Well worth the 200 if you've looked into getting this replaced... Anywhere from 600-1000 bucks.
----- With this fix, you can take that whole Vats, passlock, passkey **** system out of your car all together. Good info on both sites
It works for:
Trucks
GMC/Chevy
/Blazer/Jimmy
/Tahoe/Yukon
2003-2006 SSR
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-2005 Century
1993-2004 Regal
1982-1999 LeSabre
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1998-2002 Intrigue
1990-1992 Toronado
1997-1999 Cutlass
Chevrolet/GMC
1998-2008 Envoy
2005-2006 Equinox
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-2004 Corvette
1995-1996 Impala SS
2000-2005 Impala
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1992-2004 Seville
1992-2004 SLS/STS
1985-1999 Deville
1988-2002 ElDorado
1999-2007 Escalade
Saturn
2004-2005 L-Series
2002-2008 VUE
1996-2002 SC1/SC2
1996-2002 SW1/SW2
19helpful
9answers
HOW DO I DISABLE ANTI-THEFT SYSTEM CAR WONT START
It works for:
Trucks
GMC/Chevy
/Blazer/Jimmy
/Tahoe/Yukon
2003-2006 SSR
2003-2007 Hummer H2
Isuzu
1998-2000 Hombre
2005-2006 I280/I350
2007-2008 I290/I370
Cars/Vans
Isuzu
2003-2007 Ascender
Pontiac
1998-1999 Montana
2006 Torrent
1996-2005 Grand AM
1988-2002 Firebird
1995-2005 Sunfire
1996-2002 Trans Am
Buick
2004-2007 Rainier
1994-2005 Century
1993-2004 Regal
1982-1999 LeSabre
1982-1999 Riviera
1988-1991 Reatta
1996-1998 Skylark
Oldsmobile
1996-1998 Achieva
1999-2004 Alero
1994-2004 Aurora
1998-2004 Bravada
1991-1993 Delta 88
1998-2002 Intrigue
1990-1992 Toronado
1997-1999 Cutlass
Chevrolet/GMC
1998-2008 Envoy
2005-2006 Equinox
1997-1999 Venture
1995-2001 Lumina
1988-2002 Camaro
1995-2005 Cavalier
1982-2004 Corvette
1995-1996 Impala SS
2000-2005 Impala
1997-2003 Malibu
Cadillac
1986-1993 Allante
1982-1996 Fleetwood
1992-2004 Seville
1992-2004 SLS/STS
1985-1999 Deville
1988-2002 ElDorado
1999-2007 Escalade
Saturn
2004-2005 L-Series
2002-2008 VUE
1996-2002 SC1/SC2
1996-2002 SW1/SW2
95 caprice classic starts runs good then the doors lock and it shuts off and you wait five min and it will do it all over again. ive checked all the fuses and replaced the alternator the fuel pump fuel...
Just guessing but is there a security system in htis car?
Being a 95 it may have a factory security, the key does it have a chip built in?
You can bypass and use a regular key,
if none of these apply check idle air,
96 Chev Caprice Classic Interior lights won't shut off.
door pins may be bad, you doors may also be sagging at the hinges causing a bad connection, your lights will dim when you brake because of a draw on the battery, but it sounds like your pin switches are bad
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
