Question about American Standard Home
I want to see parts for american standard jet tub made in 2006
    Top Expert:
  • American Sta... Master
  • 64,266 Answers
Perhaps if you look on the correct website you will find what you want .
Posted on Dec 24, 2017
SOURCE:
  • 35 Answers
SOURCE: I have an american standard
Check the air vacuum switch and line as you may have a air vacuum leak. The button that controls the on and off to the jets is an air vacuum switch....It may have a slow air leak in the line or connections that is activating the on and off control
Posted on Dec 16, 2008
snap101
  • 117 Answers
SOURCE: I HAVE THE AMERICAN STANDARD WALK IN TUB WITH THE
It could be the pressure on the drain isn't allowing the rubber around the drain pop up to come unlodged from the floor of the tub. I have ran into this problem a few times. the best way we found to take care of it was to install a push pull type drain assembly or try and adjust the drain pop up so it pops up higher allowing the rubber around it to break the seal and start to drain. take some pictures and post them i might be able to help more
Posted on Jul 28, 2009
  • 80 Answers
SOURCE: how do you remove the jets on an american standard whirlpool tub
The jets have a nut on the back of the jet. I hope you have access or else you will need to pull the tub for this job. Loosen the nut and squeeze aquarium grade silicone in between the tub wall and the nut, Tighten the nut, but not to tight. Let set over night fill and check for leaks the next day.
Posted on Sep 19, 2009
  • 31 Answers
SOURCE: My American Standard whirlpool pump will only hum.
The bearings (or bushings) of the pump or pump motor have siezed, these can be replaced on some models but for the most part you will need to replace the pump and/or pump motor. and as where to get parts, i would suggest the outlet from wich you purchased the unit or another appliance outlet. Or if you feel up to the challenge, im sure you could find replacement parts on the internet: google, ebay, etc.
Posted on Sep 30, 2009
  • 80 Answers
SOURCE: i have an american standard jet tub, but i lost
You can adjust the jets by moving the center of the jet around, if the center does not move, it is not adjustable, some jets have a pressure adjustment by twisting the center of the jet left to right. No manual necessary for this.
Posted on Mar 26, 2010
Hydromassage 1063
Not normal for that to happen but the jet faces on the two back jets may be turned off or down.
Try turning the face of the jet clockwise and see if you get more water flow out of each jet.
Rod
US Parts Center
Apr 13, 2014 | American Standard Home
Have an American standard whirlpool tub. the on/off button is stuck on on. now the only way to shut the jets off is to flip the breaker to the bathroom. how do I fix this
This sounds like the air switch in the motor is not working properly. You will need to remove the pump from under the tub to access the air switch located in a housing on the motor.
Replacement Air Switch will cost you about $20
US Parts Center
Aug 27, 2013 | American Standard Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
What product to use to clean the moldy jets
Here is a link to some PRODUCTS from our site at US Parts Center that we use to clean the bacteria from the water lines and to prevent it from coming back again.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | American Standard 2083.102 Standard...
My American Standard spa tub Williamsburg Elite Model 2425E has a couple of the eight jets failing to jet, the two on either side of the rear left corner.
sounds like maybe the jet faces are turned off. see if they turn one way or the other and they may open and spew water out for you.
Dec 31, 2010 | American Standard Home
I have an american standard jet tub, but i lost
Mar 13, 2010 | Home
How to remove jets from american standard jetted tubs for routine maintenance
Jet trim usually unthread counter clockwise out of the wall fitting
Sep 21, 2009 | American Standard Home
Home Logo
69 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
