Cooking times are dependent on much more than weight. The shape of the roast, the thickness, the uniformity, the outside temperature, the quirks of your grill or oven... the only way to cook a roast properly is with a probe-type thermometer. You decide what temperature you want the center of your roast and cook it until it reaches that temperature. The lower the cooking temperature, the more evenly the roast will cook. You can Google roasting temps to give you a general idea, but if you use a recipe time, you will overcook or undercook your roast, probably, 60% of the time. Probe thermometers are cheap and reliable.
SOURCE: This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
SOURCE: oven door shot open
wine fumes ignited i would not recommend putting alchol in a closed space with 450 degrees of heat
SOURCE: convection cooking
Convection ovens are great for roasting!
I cooked a 15 lb stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
SOURCE: Braise cook chuck roast
http://www.cooks.com/rec/search/0,1-0,chuck_roast_dutch_oven,FF.html
