Question about Ryobi Drills
The light on my Ryobi 35v battery charger (for a yard blower) flashes red when I turn it on.
    Top Expert:
  • Ryobi Master
  • 64,267 Answers
You need a new battery SIR
Posted on Dec 24, 2017
SOURCE:
carlsbiz
  • 1124 Answers
SOURCE: light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Posted on Jul 31, 2009
  • 583 Answers
SOURCE: The red light always flashing when the charger is empty
many chargers do that ,i think it is to let you know thy are on and need to be turned off, when not in use
Posted on Nov 17, 2009
SOURCE: Ryobi p111 charger -- light stays red
My charger do the same thing. I talked with the service people at Ryobi who said that the red led never goes out no matter how long you charge it. They suggested just charge it for 12 hours and then disconnect. Pretty dumb system, but that's apparently the way it is.
Posted on Nov 30, 2009
  • 111 Answers
SOURCE: ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Posted on Mar 16, 2010
emissionwiz
  • 85206 Answers
SOURCE: Cannot recharge 18v battery, place
You will need to replace the battery it is defective.
Posted on May 18, 2011
I have a 12 volt Ryobi battery charger number 14050 3001 that the red light is not coming on is this indicating that the charger is no good? yellow light flashes red light never comes on
If it is charging the battery properly I would not worry about it. Just do not leave it connected all the time. Charge the battery and disconnect.
Aug 02, 2015 | Ryobi Drills
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
Try rotating the plug that goes into the wall. I know it sounds irrelevant but ive had the same issue and it worked for me. The positive and negative may be reversed in the dock.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
Battery in charger overnight, red light flashing, insert battery in drill, it doesnot work. Please advise. Thanking You Bob Falzano
If only the red light is flashing then the battery is not charging at all. Ryobi identifies in the manual that batteries will not charge below 43 degress F. If your batteries and charger are in the garage in a cold climate, warm the batteries to room temp in the house and then try again. If the charge starts when the batteries are warm they will continue charging for the full cycle even in a cold area.
Dec 24, 2010 | Ryobi Multi-Volt Battery Charger
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
My Ryobi 18V 1-Hour Charger does not get past testing phase. It just continually has the flashing red light. Can this be fixed or is a new one required?
Purchaseed Roybi P2102 cordless blower at Home Depot yesterday. Put battery on charger for 12 hours and it would not get past the "test" phase. Called Ryobi customer service 800-860-4050 (got a live person quickly), was told I had two options: take the blower back to HD for refund/exchange OR take it to the Tool Rental or Pro Desk at HD and they can test the charger/battery and can provide a replacement if defective, all FREE of course.
Nov 01, 2010 | Ryobi Multi-Volt Battery Charger
Nov 08, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Drills Logo
59 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
roeb
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
